Librecad on vintage WinXP PC
11 messages Options
Librecad on vintage WinXP PC – I am using the program on a WinXP PC which is not (for its health) connected to the web. On reinstalling Librecad, i couldnt get the program to ru...
I have just tested to install LibreCAD on WinXP SP2 disconnected from the web, there was no problem at all. The versions 2.2.0 rc from 201 on don...
It is correct, that the installer opens the browser to show the donation site. This results in a 404 error in the browser without internet connec...
The OS on this PC is WinXP SP2 (registered), and the CPU is AMD 1.14GHz. The file LibreCad.2.0.0-en-win.exe (27.517kB of 2017-11-20) installs t...
I have tried another experiment. On that old 500Mhz 256 MB RAM laptop I ran a PuppyLinux upupbb32-light live CD and tried to install LC 2.1.3. It ...
Please do look at it from an end users viewpoint: If You have an arrangement of several PCs, each with its own peripherals and tasks, would you wa...
Searching for this 0xc000001d error message, the tenor is that the hardware is too old. Some solved this issue with BIOS updates, but success is ...
The only variable in this game is the LibreCad version. If the old 2.0.0 runs, but the newer ones don't, then it is reasonable to assume, that som...
I have just checked: On an even more ancient Toshiba laptop 500 Mhz and 256 mb RAM I have LC 2.0.3 running from portable, so hardware does not see...
Maybe some remains from the 2.2.0 installation (in the registry for example) blocks the execution of newer versions. I would try out the portable ...
Thanks for your effort. Unfortunately, the version LibreCAD-XP-Installer-2.2.0-rc1-257-gca256068.exe gives the same problem. Please see my ans...
