[POLYLINE, PDF] 2 Bugs in Api
10 messages Options
emanuel
I discovered a bug.
When I draw a polyline and change its width, it becomes invisible.
See the video attached.
simplescreenrecorder-2025-04-01_20.mp4
Oh my god, the script functions entget, entmake, entmod, etc. are taking me months...
Re: [POLYLINE] Bug in Api
I think we should go restore RAII style rendering pen.
We had that in 2.2.1, but removed in master.
RAII is for exception safety as well as proof of correctness.
emanuel wrote
I discovered a bug.
Re: [POLYLINE, IMAGE] 3 Bugs in Api
emanuel
Unfortunately, we still have two annoying bugs.
When I add an image, it's also invisible.
When I try to add a PDF, LibreCAD crashes ;-(
Watch the video:
simplescreenrecorder-2025-04-02_14.mp4
sand1024
Well, I've found it - this issue actually not related to rendering, it's related to earlier incorrect calculation of bounding rect (minV, MaxV for polylin) after editing operation. So polyline becomes outside of the screen bounding box). I'll apply a fix
sand1024
add a PDF? Hmm... how and where? Could you please expand on this?
UPD: Oh, noticed this in your video. I suppose we should apply more strict to image format. PDF is definitely is not something correct that is expected there, AFIK pdf is not supported at all ...
emanuel
See the last video above in the attachment.
Command: File->Import->Import Image (PDF selected)
sand1024
No, it's visible - but, in the draft mode, only boundary box for the image is drawn.
Please try to disable to Draft mode and check again (the button near to the Grid in the toolbar).
sand1024
Yes, it was my fault. Fixed it already and I'll commit the fix with nearest PR.
emanuel
picture is visible now.
pdf still crashes.
A pdf is not an image file. Primarily it is a vector format, it may contain an image additionally. But it can not be imported into LibreCAD, it's also not in the list of possible image formats to be imported.
