Text file
Text file – Is it possible to import a text file which contain plot coordinates and have the plot coordinates plotted automatically by LibreCad?
I think the Read ascii points plugin is what you are looking for. See http://forum.librecad.org/Reading-ASCII-points-td5706664.html Armin
Hello Armin! With regard to subject plugin:  LibreCAD manual, accessed via LibreCAD "Help" menu,  shows an interesting example, at v...
After further research I've discovered my inquires  on this matter is covered, seemingly, in depth.  Thank you Arimin, and please disregard my l...
Thanks. I looked at that awhile back, and wondered if there wasn't a more direct and simpler way. Have you used this method?
No, I had not, never had a use case for this plugin. If the plugin is too inconvenient for you, have a look at this: http://forum.librecad.org/K...
