The function « prolonger deux » has changed?
Carnyx
I‘ve been using the 1.0.2 version for a long time. I have downloaded  the 2.0.0 beta and there is a change in a particular function : Menu “Modify” / “prolonger deux” (in French, the number eight function)
I can’t joint two circle arcs as I did with the 1.0.2 versions, using “prolonger deux”
Re: The function « prolonger deux » has changed?
Siprex3D
Hello world
Salut Carnyx (I'm french too)
You mean "Modify / Trim two" in purpose to extend two lines.
