Trim AND Extend
Trim AND Extend
jp willm
Bonjour,
How to extend lines in LibreCAD : I searched for a long time and found nothing
Today, I discover that Modify > Trim is able to Extend lines !
https://www.youtube.com/watch?v=gleSdd6msBs
Now, I ask : why this perfect tool is named "Trim" and not "Trim/Extend" ?
If the name had been "Trim/Extend", I would have found for a long time how to extend lines in LibreCAD
Is it possible to rename this icon in "Trim/Extend" ?
Many users would appreciate to know how to extend lines in LibreCAD
jp willm
Re: Trim AND Extend
Bruno
Hello
wonderful software. I'm using it currently in my designs.
Probably there are some tricks that I don't know yet.
I would suggest you some improvements.
1-The trim/extent command as the colleague mentioned above.
About trim command, please do the multiple selection. I don't know but it doesn't work inside this command.
2-I experienced some troubles moving/copying text. I'm using 2.2.0 alpha.
3-The possibility to use the window zoom inside a command.
4-Multiple style dimensions.
Thank you very much indeed
Wonderful work anyway.
Best Regards
Bruno
Bruno Zilli
Designer, CEng,
second level master in computational mechanics
NDT level 3
Re: Trim AND Extend
jp willm
Thank you for your interesting email.
Yes, LibreCAD is a very good tool for 2D.
I used it a lot when I was still working, but not anymore, because I only draw in 3D.
FreeCAD has recently been equipped with a TechDraw workbench which allows you to easily export 3D objects to 2D views and add all kinds of dimensions.
Best Regards ,
jp willm
Re: Trim AND Extend
fa201
You can use lengthen feature:
https://librecad.readthedocs.io/en/latest/ref/tools.html#modify
Fabrice
Re: Trim AND Extend
Bruno
In reply to this post by jp willm
bonjour M. Willms
moi aussi, j'utilise le 3D, et j'ai fait comme vous avez dit.
J'ai vu votres pages.
Vous avez fait un travail trés interessant avec Freecad.
Je vais l'utilizer dans la proxieme commande.
Merci.
Salutations
Bruno
Bruno Zilli
Designer, CEng,
NDT level 3
Re: Trim AND Extend
jp willm
Bonjour Bruno,
Bon, mon but n'est pas de faire de la publicité pour FreeCAD sur le forum LibreCAD :-/
LibreCAD est excellent et incontournable dès lors que l'on veut faire des plans sérieux en 2D.
Merci pour votre appréciation.
Si vous avez des questions ou suggestions sur FreeCAD, sous pouvez les ajouter sous mes vidéos plutôt qu'ici...
Bruno wrote
Merci.
Salutations
Avec plaisir.
