Trim doesn't work
Trim doesn't work
MT500
Just installed 2.1.3. I cannot trim two overlapping rectangles to form one entity. After typing "tm" it invites me to select the limiting entity but I can't select anything. I've tried changing the "selected line" colour but nothing happens. Any ideas?
Re: Trim doesn't work
Trikester
This is just a guess but the four lines in a rectangle, created by using the rectangle tool, may be treated as a single element. You could try exploding the rectangle.
In AutoCAD LT a rectangle created using the rectangle tool did act as a single element, or like a block, as I recall. If you didn't explode it and tried to erase one of the sides the whole rectangle would be erased.
Trikester
In reply to this post by MT500
MT500
In reply to this post by Trikester
Thanks. I'd forgotten that one. :-)
