Hi all,
From a drawing (DXF format that was converted from DWG) I need to copy some objects to another drawing in LibreCAD.
I follow the method described
here.
It works, but the pasted object become larger (very large).
I check the dimension on the source DXF file is OK.
I also check, there is no problem if I do the same method (copying) from another libreCAD drawing.
Did I miss something? Or is it because from previously converted file (thus, no solution?)?
Thanks for the help.
Version: 2.1.2
Compiler: GNU GCC 6.2.0
Compiled on: Sep 17 2016
Qt Version: 5.9.5
Boost Version: 1.62.0
System: Ubuntu 18.04.5 LTS
