hatch with fillet
hatch with fillet
aman
Librecad 2.1.3, Debian 10 Buster stable.
Can't hatch entity if there are fillets, is this a feature, or is there a trick to overcome this behaviour?
Re: hatch with fillet
This works for me with fillets.
You should not select the horizontal line which stops the hatch.
Select only the outline entities, then it should work.
aman
Thanks a lot LordOfBikes, that was the right solution!
No problem, you're welcome.
