only empty boxes/frames are shown for image/text? no line thickness?
Next Topic
You need to disable "Draft" mode. Make sure you uncheck the following item:
Main menu: View->Draft
Re: only empty boxes/frames are shown for image/text? no line thickness?
sp1der
The Icon has changed since version 2.1
dcas2020
Thank you Lord of Bikes,
 ' draft ' mode was set and  causing my problem,
cleared it and OK now.
cheers,
Denis
follaiv@alice.it
Thanks a lot I solve the problem by click on the Draft Mode as you suggest
I the latest development version, "Draft" will be shown on in the corners of the drawing view. Hopefully, we will confuse users less.
