ASCII file format
2 messages Options Options
ASCII file format
seckford
Does anyone know if the format of an "imported ASCII" file is documented
anywhere?  I've tried various layouts, including one that's mentioned on
this board, and I always get the error message: dibpunto procesFile.
Thanks - Will
Re: ASCII file format
The format is:
N,X,Y,Z,C
where:
N = point number
X = x data (east)
Y = y data (north)
Z = z data (elevation)
C = code like "wall" "axis" "pine" etc. (optional)
decimal sepparator allways is point.
field separator can be:
tabulator, space or comma.
The message "dibpunto procesFile" are for information
and a more correct message is "Processing ascii file..."
Note that if the current view is from 0,0 to 240,120 (p.e.)
and points have a extension from 500,500 to 1000,700 (p.e.)
seems that did not work.
When the plugin ends you must run "View->Auto zoom" or
double click with middle button mouse
