Is there a bug ???
10 messages Options Options
Is there a bug ???
l'AMI Yves
I'm totally newby, so I may commit mistake, but I can't understand what happens : in the current drawing, I create a new layer, view it and select it, then I try to import a dxf file : it comes into layer 0 !
Sometimes, after "I-can't-remember-what" operation, some entities can be visible only if two layers are visible : they desapear if either layer (or two) are not visible.
Can anybody explain that (LibreCAD V2.0.0Beta1 Oct 29 2012)
Re: Is there a bug ???
Hello Yves,
Not a bug.
When you import a dxf into another dxf you are appended it as block (File->import->Block)
and all imported entities maintain their properties (color, linetype, layer, etc.)
The "two layers" case are related to Blocks and Inserts, and neither is a bug.
To better understand the operation of blocks see these threads:
http://forum.librecad.org/Block-can-not-be-inserted-on-different-layers-td5544026.html
http://forum.librecad.org/How-could-I-fetch-the-block-and-entity-information-td5707314.html
http://forum.librecad.org/How-to-change-the-color-of-an-existed-entity-td5707346.html
l'AMI Yves
1 post
Thank's Rallaz. It's very kind of you to answair so much basic and recurrent questions.
In fact, the most difficult thing to learn with a new program is it's ergonomy, and I have much trouble with it !
At the moment, I will try not to use blocks, that I do not understand enough. And I have other problems...
At a moment, I had to draw a line "with two points" (a segment), and it worked well. Then I try again (in the meantime I went to some snap restrictions, but there are no more). I indicate the first point, then the second, and the machine draws the whole line ! I ask again my question : "Is there a bug ?"
Thank's again.
LibreCAD has bugs, of course, but you have not found none yet
When you set a layer not printable (print icon in layer list) are converted as "auxiliary layer" and lines
are drawn infinite. Check by click in "print icon"
l'AMI Yves
1 post
Once again, thank you very much. I'm affraid I'll ask a lot of questions till I'm "fluent" with LibreCAD.
l'AMI Yves
I have also to become "fluent" with forum.libreCAG.org... I was frustrated not to view my avatar... Hope I understood now
l'AMI Yves
Arrhhh ! Of course, I don't think it's a bug... but I don't understand why some layers get unwillingly the "Help layer" attribute.
And I have a layer on which I imported a drawing (JPEG), and I copy some lines of the drawings as polylines on other layers. Sometimes, those "other layers" seem to be "under" the drawing, and so I can't see them (obviously, the corresponding layers are supposed to be visible, and I see them if I make the drawing layer invisible).
Thanks for patience.
Ok This at last found a bug... but late
Seems you have foud the same bug as ePoxi user in this thead:
http://forum.librecad.org/Lines-went-to-infinity-td5707037.html
If it is the same, are solved, but you can wait for next windows relsease: beta2 or RC1
About using JPEG the layer order are not relevant on paint screen. You use "Edit->draw order"
submenu to move image to bottom
l'AMI Yves
OK, I'll wait for Beta2. Is it schedulled ?
But I asked for two things : The question of draw order. I could'nt find again then phenomenon. At the first occasion, I'll test "Draw order"
Thanks again and again.
This post was updated on Apr 16, 2013; 10:20am.
Beta2 will be published shortly but there is no date yet.
You can use this file (only uncompress and use)
http://sourceforge.net/projects/rallaz.u/files/librecad-win/librecad2.0.0beta1-git2013-04-16.7z/download
About "Edit->draw order" is menu "Edit", submenu "draw order" then "move to bottom" the JPEG image
