Building LibreCAD from Github fork
7 messages Options
joseph_oc
I hope this makes sense: Ive prepared the following note from my journal.
my system configuration partly includes the following:
Qt Creater 1.3.1
Based on Qt 4.6.3 (32 bit)
Built on Oct 6 2010 at 11:57:38
Maybe the version of Qt Creater I am using is at fault?
I have NOT saved my edit, I am still on the librecad project as I downloaded.
• Steps:
Caution: my lingo may be off, never tried to 'run' (build) such a large project!!
1) Created my free git account.
2) forked the 'master branch' of the  https://github.com/LibreCAD/LibreCAD repository
3) executed the following command from a Bash shell:
                git clone git://github.com/joseph-oc/LibreCAD
4) attempted to build all of the 'forked' repo within QtCreated. build all 'librecad'.
5) received the following error output from the compiler:
lib/engine/rs_ellipse.h:363: error: expected ';' before 'private'
make[2]: *** [../../generated/librecad/obj/rs_actioninterface.o] Error 1
make[2]: Leaving directory `/home/joseph/LibreCAD/librecad/src'
make[1]: Leaving directory `/home/joseph/LibreCAD/librecad'
make: Leaving directory `/home/joseph/LibreCAD'
make[1]: *** [sub-src-make_default] Error 2
make: *** [sub-librecad-make_default-ordered] Error 2
Exited with code 2.
Error while building project librecad
When executing build step 'Make'
6) went into rs_ellipse.h, line 363 did compiler recommended edit before 'private' (ADDED SEMI-COLON) and received the following error:
lib/engine/rs_ellipse.h:345: error: expected ';' before '<' token
Exited with code 2.
7) do not want to proceed with my own additions regarding "Surveying" until I can get a clean copy on my system.
That is where I stand.  Look forward to comments and suggestions so I can move on.
Thanks so much for your time.
Sincerely,
Joe O
Re: Building LibreCAD from Github fork
lib/engine/rs_ellipse.h:363 are
private:
and g++ error says:
That is, error are BEFORE 363 aka line 362 or previous and previous definition is:
 boost::fusion::tuple<double, double, double> operator()(double const& z) const {
then your problem can be solved installing boost-devel (muparser-devel are also required)
joseph_oc
Rallaz and others:
I have successfully installed the libboost-devl.
The build no longer gives errors relating to that library.
Unfortunately, the libmuparser library is still issuing errors.  I paste the compiler output below.
I installed libmuparcer0 Ver 1.32-1 and libmuparser-dev Ver 1.32-1.
I have seen posting librecad forums regarding issues with the math libraries.  There seems to be issues with the versions of g++ and libmuparser, at least
I have had dependency issues trying to upgrade these files.
Rallaz, if you can tell me the versions I should usef with regards to these issues and give me links to there locations, I am hoping to complete the compiling and have a functional configuration. Thanks
Below are the compete compiler output from my last build, the above seems to be the issues.
Running build steps for project librecad...
Configuration unchanged, skipping QMake step.
Starting: /usr/bin/make -w
make: Entering directory `/home/joseph/LibreCAD'
cd libraries/ && /usr/bin/make -f Makefile
make[1]: Entering directory `/home/joseph/LibreCAD/libraries'
cd libdxfrw/ && /usr/bin/make -f Makefile
make[2]: Entering directory `/home/joseph/LibreCAD/libraries/libdxfrw'
make[2]: Nothing to be done for `first'.
make[2]: Leaving directory `/home/joseph/LibreCAD/libraries/libdxfrw'
cd jwwlib/ && /usr/bin/make -f Makefile
make[2]: Entering directory `/home/joseph/LibreCAD/libraries/jwwlib'
make[2]: Leaving directory `/home/joseph/LibreCAD/libraries/jwwlib'
make[1]: Leaving directory `/home/joseph/LibreCAD/libraries'
cd librecad/ && /usr/bin/make -f Makefile
make[1]: Entering directory `/home/joseph/LibreCAD/librecad'
cd src/ && /usr/bin/make -f Makefile
make[2]: Entering directory `/home/joseph/LibreCAD/librecad/src'
g++ -c -pipe -std=c++0x -g -std=c++0x -Wall -W -D_REENTRANT -DQC_APPKEY="/LibreCAD" -DQC_APPNAME="LibreCAD" -DQC_COMPANYNAME="LibreCAD" -DQC_COMPANYKEY="LibreCAD" -DQC_VERSION="master" -DQC_DELAYED_SPLASH_SCREEN=1 -DHAS_BOOST=1 -DQC_SCMREVISION="2.0.0beta1-127-g0e8950a" -DQC_APPDIR="librecad" -DQINITIMAGES_LIBRECAD=qInitImages_librecad -DQT_SVG_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtSql -I/usr/include/qt4/QtSvg -I/usr/include/qt4 -I/usr/include/qt4/QtHelp -I../../libraries/libdxfrw/src -I../../libraries/jwwlib/src -Icmd -Ilib/actions -Ilib/creation -Ilib/debug -Ilib/engine -Ilib/fileio -Ilib/filters -Ilib/gui -Ilib/information -Ilib/math -Ilib/modification -Ilib/scripting -Iactions -Imain -Iplugins -Iui -Iui/forms -I../res -I../../generated/librecad/moc -I../../generated/librecad/ui -o ../../generated/librecad/obj/rs_math.o lib/math/rs_math.cpp
lib/math/rs_math.cpp:33:22: error: muParser.h: No such file or directory
lib/math/rs_math.cpp: In static member function 'static double RS_Math::eval(const QString&, bool*)':
lib/math/rs_math.cpp:301: error: 'mu' has not been declared
lib/math/rs_math.cpp:301: error: expected ';' before 'p'
lib/math/rs_math.cpp:302: error: 'p' was not declared in this scope
lib/math/rs_math.cpp:307: error: expected type-specifier before 'mu'
lib/math/rs_math.cpp:307: error: expected ')' before '::' token
lib/math/rs_math.cpp:307: error: expected '{' before '::' token
lib/math/rs_math.cpp:307: error: '::Parser' has not been declared
lib/math/rs_math.cpp:307: error: 'e' was not declared in this scope
lib/math/rs_math.cpp:307: error: expected ';' before ')' token
make[2]: *** [../../generated/librecad/obj/rs_math.o] Error 1
Exited with code 2.
Thanks for your time!!!!
Joe O,
Please, remember to comment what is yuor system always seems to make things easier
make: Entering directory `/home/joseph/LibreCAD' => seems you are in linux
libmuparser-dev Ver 1.32-1 => seems Debian squeezy
Compiler error:
Verify if libmuparser-dev are correct installed ( if exist /usr/include/muParser/muParser.h)
Verify in settings_linux.pro if these lines exist:
    exists("/usr/include/muParser") {
       INCLUDEPATH += "/usr/include/muParser"
Delete /home/joseph/LibreCAD/Makefile and /home/joseph/LibreCAD/librecad/src/Makefile
and run qmake to regenerate makefiles
If you are using qtcreator select the top project and click in "Build->Run qmake"
joseph_oc
Rallaz and others:
Regarding previous POST:
SYSTEM:
My system is a linux kernal
Debian Squeeze Ver 6.07
HARDWARE:
Intel processor (Dual Core Pentium)
an older laptop "TOSHIBA"-Satellite
Compiling is slow, but programs run fine.
I have had 2 broken packages, but was able to remove and reinstall without a problem.
Compiler Error:
File muParser.h exists in the correct directory
The line of code you where questioning exists in settings_linux.pro
I deleted the 2 'Makefile'(s)
qmake successfully regenerated the makefiles
That was the end of my success.
I did get a lot further but BUILD librecad gave errors after about 15 minutes into Build (1st time I only got 2 mins into BUILD).
This was the first build issue:
/home/joseph/LibreCAD/tools/ttf2lff/main.cpp:33: error: ft2build.h: No such file or directory
I searched for that "include" (ft2build.h) file and it does not seem to exist.
I searched /usr/include on the system and /home/joseph/LibreCAD and /usr/lib
I think I searched the whole filesystem, no luck.  Where should it be?
FT_Library does not seem to exist.
Compile Outputs
main.cpp:80: error: expected primary-expression before 'void'
make[2]: Leaving directory `/home/joseph/LibreCAD/tools/ttf2lff'
make[2]: *** [../../generated/tools/ttf2lff/obj/main.o] Error 1
make[1]: Leaving directory `/home/joseph/LibreCAD/tools'
make[1]: *** [sub-ttf2lff-make_default] Error 2
make: *** [sub-tools-make_default-ordered] Error 2
Exited with code 2.
FIRST Build Issue:
I believe this is the line 80 (along with the remainder of the function) in /home/joseph/LibreCAD/tools/ttf2lff/main.cpp that the Compiler is complaining about.
int moveTo(FT_Vector* to, void* fp) {
    if (firstpass) {
        if (to->x < xMin)
            xMin = to->x;
    } else {
        prevx = to->x;
        prevy = to->y;
        if (fp!=NULL) {
            if (startcontour) {
                startcontour = false;
                fprintf((FILE*)fp, "%s,%s",clearZeros((double)(to->x-xMin)*factor).c_str(), clearZeros((double)to->y*factor).c_str());
            } else {
                fprintf((FILE*)fp, "\n%s,%s",clearZeros((double)(to->x-xMin)*factor).c_str(), clearZeros((double)to->y*factor).c_str());
    return 0;
Thanks for your time.
Joe O
PS Thanks so much for assistance and time!!!
end of post
we have a simplified building howto for linux:
On Fri, Mar 29, 2013 at 9:36 AM, joseph_oc [via LibreCAD] <[hidden email]> wrote:
Rallaz and others:
SYSTEM:
HARDWARE:
Compiler Error:
Compile Outputs
Exited with code 2.
FIRST Build Issue:
    if (firstpass) {
        if (to->x < xMin)
            xMin = to->x;
    } else {
        prevx = to->x;
        prevy = to->y;
        if (fp!=NULL) {
            if (startcontour) {
            } else {
    return 0;
Joe O
end of post
http://forum.librecad.org/Building-LibreCAD-from-Github-fork-tp5707778p5707795.html
Dongxu Li, Ph.D.
www.librecad.org
In reply to this post by joseph_oc
http://librecad.org/cms/home/from-source/linux.html
 sudo apt-get install g++ gcc make git-core libqt4-dev qt4-qmake libqt4-help qt4-dev-tools libboost-all-dev libmuparser-dev libfreetype6-dev
or:
sudo apt-get build-dep librecad
On Fri, Mar 29, 2013 at 10:21 AM, Dongxu Li <[hidden email]> wrote:
Rallaz and others:
SYSTEM:
HARDWARE:
Compiler Error:
Compile Outputs
Exited with code 2.
FIRST Build Issue:
    if (firstpass) {
        if (to->x < xMin)
            xMin = to->x;
    } else {
        prevx = to->x;
        prevy = to->y;
        if (fp!=NULL) {
            if (startcontour) {
            } else {
    return 0;
Joe O
end of post
Dongxu Li, Ph.D.
www.librecad.org
Dongxu Li, Ph.D.
www.librecad.org
