GSoC 2014: Introduction
18 messages Options
priyanka
Hello everyone,
I am Priyanka Kapoor pursuing B.Tech IT from Guru Nanak Dev Engg. College, Ludhiana. I have been working on LibreCAD from past one year. I also try my hands changing the source code of LibreCAD to add new shapes like a flower of circles, synchronizing the text boxes of dimension dialog box. I explained the work on my blog also. I am keen interested in C++ and Qt. I have good knowledge of making / designing User interface in Qt.
As for my project, I am interested in "SmartSnape" project. This project needs a logic that will convert the units entered by user to unit used in LibreCAD. I am writing my proposal and I will post by today evening.
I heartily congratulate LibreCAD for being part of GSoC 2014. Looking forward for your guidance and support in project.
Regards,
Priyanka
(Blog)
Re: GSoC 2014: Introduction
Hi priyanka,
jasleen once reported "flower" entities, very interesting addons.
As we are talking about creating a new LibreCAD engine now. I'm wondering whether your new architecture is designed with a new engine in mind.
For snapping, make sure we have smart constraints which are missing in LibreCAD. For example, snap to perpendicular, etc.
Please talk to us more on IRC for new ideas.
Thanks,
priyanka wrote
Hello everyone,
Regards,
Priyanka
(Blog)
priyanka
There is a confusion going on. Project Idea list was showing two projects with different names but same description.
I was proposing for Supporting Multiple Measuring units in LibreCAD. I thought you gave SmartSnape as short name to this project. So I wrote there SmartSnape.
Supporting Multiple Measuring units will be  sort of library file, which can be easily included in new engine.
Am I on right track now? Please do respond/point out if I am wrong at some place regarding this project.
priyanka
On Fri, Mar 21, 2014 at 12:20 AM, R. van Twisk [via LibreCAD]
<[hidden email]> wrote:
> Hey Priyanka,
> this morning I got notified that the description was changed so I changed it
> to the right description back again.
> I think you want to propose on the project : Support for multiple units upon
> data entry.
Yes I want to propose on this project.
> let me know if that was right,
> Have you been on our IRC channel? #[hidden email]
Yes, with name priyanka. I used to ask questions on IRC one year back
with this name. I will be there from
now onwards.
> Ries
> ________________________________
> If you reply to this email, your message will be added to the discussion
> below:
> http://forum.librecad.org/GSoC-2014-Introduction-tp5709705p5709709.html
> To unsubscribe from GSoC 2014: Introduction, click here.
> NAML
Priyanka Kapoor
priyankacool10.wordpress.com
Linux User Group, Ludhiana
muparser actually supports units in input:
http://muparser.beltoforion.de/mup_features.html
I feel you may consider expanding the muparser usage/features in LC. Are there any good alternative for muparser?
Maybe not so relevant? can we enable python binding, either use python binding for math or command line interface.
priyanka
On Fri, Mar 21, 2014 at 5:24 AM, dxli [via LibreCAD]
dxli, what if we pre-parse the expression  before passing it to muparser?
We just need a pre-parser, all the rest will go same as doing currently.
I don't think that we need much of mathematical calculations for this
project. muparser is more than enough. It supports strings, and we can
do pre-parse the string easily before passing to muparser.
We just need to design a grammer for user input and parsing it to unit
used in LibreCAD.
What are your views in this?
Priyanka Kapoor
priyanka
Please review my proposal.
http://brlcad.org/wiki/User:Priyanka_kapoor
Priyanka Kapoor
Jasleen never shared "flower" source code, do you mind sending a pull request to my github master branch:
github.com:dxli/LibreCAD.git
Thanks!
priyanka
On Fri, Apr 4, 2014 at 4:42 PM, dxli [via LibreCAD]
dxli, I just tweaked the code of circle to make a flower pattern, and
it is not a new feature, just a couple of lines.
You can see that here:
http://priyankacool10.wordpress.com/2013/03/31/changing-functionality-of-circle-in-librecad/
Priyanka Kapoor
priyanka
@dxli,
In continuation to yesterday's discussion on IRC, I implemented that
flower with the icon on Toolbar.
Here are the screenshots.
http://www.picpaste.com/flo1-RRsqe7uQ.png
http://www.picpaste.com/flo2-jq0II9Ma.png
Priyanka Kapoor
modified a little bit
flower
priyanka
Sorry. I didn't get you.
flower
http://forum.librecad.org/GSoC-2014-Introduction-tp5709705p5709745.html
Priyanka Kapoor
priyanka
I have done with user input too. User enters the no. of petals to draw.
You can see that flower icon in toolbar, flower option (petals) widget on top bar. In second screenshot, Flower option is in drop down list. I am happy that I am able to implement flower in separate files, along with user input and I understood all files linking associated with this pattern.
But there is a problem. It works fine when user enters 6.
But it draws one extra circle if user enters less than 6 and one less circle when user enters more than 6.
Here is that code:
RS_Circle* flower;
    flower = new RS_Circle(container, data); // circle in center
    flower->setLayerToActive();
    flower->setPenToActive();
    container->addEntity(flower);
    int i = petal; // ASK THE USER (integer)
    //double r = M_PI/(2.0*i);
    double radian = 0.0;
    while (i--)
    //radian+=r;
    flower = new RS_Circle(*flower);
    radian=( (i==6)?2:2*(5-i))*M_PI/6;
    flower->move(RS_Vector(radian)*data.radius);
[1] http://www.picpaste.com/patch-AVXWzu5u.png
[2] http://www.picpaste.com/patch2-ju9d61M9.png
Priyanka Kapoor
petal calculation needs to be updated as well:
void RS_ActionDrawCircle::trigger() {
    RS_PreviewActionInterface::trigger();
    deletePreview();
    //    RS_Circle* circle = new RS_Circle(container, data);
    QList<RS_AtomicEntity*> lists;
    RS_Circle* flower= new RS_Circle(container, data); // circle in center
    lists<<flower;
    //        flower->setLayerToActive();
    //        flower->setPenToActive();
    //        container->addEntity(flower);
    static int petal=3; //remember previous # petals
    double offset=2.*data.radius*sin(M_PI/petal);
    while (i--)
        // x + 2 2 pi/t = pi/2 + pi/t , // first offset direction is Pi/2 + Pi/petal
        // x= pi/t( -4 + t/2 + 1), (2 + 2i)
        // (t/2 -3 + (t -i)*2) p/t
        if(i==petal-1)
            flower->move(RS_Vector(data.radius, 0.));
        else
            flower->move(RS_Vector(((petal -i)*2 + 0.5*petal - 3.)*M_PI/petal)*offset);
        lists<<flower;
    for(RS_AtomicEntity* c: lists){
        c->setLayerToActive();
        c->setPenToActive();
        container->addEntity(c);
    if (document!=NULL) {
        document->startUndoCycle();
            document->addUndoable(c);
        document->endUndoCycle();
    // upd. undo list:
    graphicView->redraw(RS2::RedrawDrawing);
    graphicView->moveRelativeZero(data.center);
    setStatus(SetCenter);
    reset();
    //increase # of petals for the subsequent session
    petal++;
    if(petal>=20) petal=3;
//    RS_DEBUG->print("RS_ActionDrawCircle::trigger(): circle added: %d",
//                    circle->getId());
priyanka
dxli, its working great :) Your mathematics is fantastic.
I can send you pull request now.
priyanka
Here is the pull request:
https://github.com/dxli/LibreCAD/pull/10
On Mon, Apr 7, 2014 at 8:32 AM, Priyanka Kapoor
Priyanka Kapoor
