HOWTO: Compiling LibreCAD with GCC 4.7 and Clang
4 messages Options Options
feugeniy
I found instruction howto compile Qt-projects using GCC 4.7 and Clang (on Russian site):
http://m.habrahabr.ru/post/144707/
Who can translate and adopte this instruction for LibreCAD?
Re: HOWTO: Compiling LibreCAD with GCC 4.7 and Clang
LC has no problem with gcc-4.7, as a matter of fact, I remember some building problems with older gcc versions, such as 4.4.
clang support is interesting enough though.
On Tue, May 29, 2012 at 5:47 AM, feugeniy [via LibreCAD] <[hidden email]> wrote:
http://forum.librecad.org/HOWTO-Compiling-LibreCAD-with-GCC-4-7-and-Clang-tp5706711.html
Dongxu Li, Ph.D.
www.librecad.org
Some time ago I experimented with clang on OSX.
and although it did compile the application felt a lot slower then compiled with c++
Ries
On Tue, May 29, 2012 at 5:47 AM, feugeniy [via LibreCAD] <<a href="x-msg://952/user/SendEmail.jtp?type=node&amp;node=5706712&amp;i=0" target="_top" rel="nofollow" link="external">[hidden email]> wrote:
To start a new topic under LibreCAD-dev, email <a href="x-msg://952/user/SendEmail.jtp?type=node&amp;node=5706712&amp;i=1" target="_top" rel="nofollow" link="external">[hidden email]
To unsubscribe from LibreCAD-dev, <a href="x-msg://952/" target="_blank" rel="nofollow" link="external">click here.
Dongxu Li, Ph.D.
www.librecad.org
http://forum.librecad.org/HOWTO-Compiling-LibreCAD-with-GCC-4-7-and-Clang-tp5706711p5706712.html
sounds good, so we can confirm it builds with gcc/clang/msvc
