Help please.
Help please.
ShinRevolver
Hi there. I would like to ask, where in the code is the part where png, jpeg, svg, etc. files are created? Not the one with void QC_ApplicationWindow::slotFileExport(); Because I want to try and implement if I can export exif or jp2 files.
Much appreciated. Thanks.
Re: Help please.
it's handled within QC_ApplicationWindow::slotFileExport().  The actual drawing happens line 3232:
   for (RS_Entity* e=graphic->firstEntity(RS2::ResolveAll);
            e!=NULL; e=graphic->nextEntity(RS2::ResolveAll)) {
        gv.drawEntity(&painter, e);
where painter is RS_PainterQt
Re: Help please.
ShinRevolver
Could you explain how this part works? I'm kinda confused.
Re: Help please.
ShinRevolver
I added this bit of code supportedImageFormats.append("jp2"); (together with the similar add svg code at about 3054) to the QC_ApplicationWindow::slotFileExport().
And since it fails to export, what other parts am I still missing? Also, I don't quite understand RS_PainterQt.
Re: Help please.
RS_PainterQt translate entity drawing actions to supported QPainter() drawing actions.
Read the source code of RS_PainterQt, and you can see how entities are drawn.
On Tue, Feb 11, 2014 at 11:34 AM, ShinRevolver [via LibreCAD] <[hidden email]> wrote:
http://forum.librecad.org/Help-please-tp5709539p5709544.html
Dongxu Li, Ph.D.
www.librecad.org
