PNG files
10 messages Options
PNG files
ShinRevolver
Has anyone here used pngwriter? Its a library that creates a .png file. I trying to add it as a library to see if I can save any drawing as a .png file. Its mainly a school project. Any tips? I'm new here. Thanks.
Re: PNG files
sp1der
LibreCAD can already save a drawing to a .png format, is this no good for you?
Re: PNG files
ShinRevolver
Oh. Snap. Scratch that idea. Know any simple ones that I can implement? I would greatly appreciate it.
Re: PNG files
It may work, to create your own painter class similar to RS_Painter.
You need to replace all drawing methods there (RS_Painter) to use pngwriter.
It sounds quite lots of work.
Re: PNG files
ShinRevolver
I'll look into it. Thanks.
Re: PNG files
ShinRevolver
Can you tell me where the code for the export of features(to png, to jpeg, etc.) is located? I can't seem to locate it. Thanks.
Re: PNG files
void QC_ApplicationWindow::slotFileExport() ;
Re: PNG files
ShinRevolver
Thanks. This is in terms of the UI, if I'm not mistaken. Where do you put the code in order for it to create the file(i.e png, jpeg, etc.)?
Re: PNG files
the code to generate an image file in line 3249,
        if (iio.write(img)) {
            ret = true;
Re: PNG files
ShinRevolver
Thanks.
