		When I open a dxf file ( which contains many blocks and line entitys),
				I want to know each information (color ,vector ) of objects for 1. all entities 2. all blocks I notice that RS_Graphic -> RS_BlockList blockList might fetch the block list ? RS_GraphicView -> RS_EntityContainer* container; // Holds a pointer to all the enties are these the collection of all entities and all blocks ? if that, I am just confused why not there are defined in one class . BTW, I want to change the color by programming. how to do that ? Thanks.  |
		First, read my comment:
				http://forum.librecad.org/Block-can-not-be-inserted-on-different-layers-td5544026.html#a5544807 If you want to write a plugin, you can modify a bit "list plugin" and you have what you need.  |
	 Hi Rallaz
Would you take a look at this dxf ?
it contains :
1. several blocks (which composed by a text and a rect )
2. several line which connect different blocks.
I want to change the color of each blocks or lines as I wanted by
programming.  I will use block name such as "159-124...." to find the
block. is it reasonable ? then change the color of the blocks(actually it's
just a entity container , I might change the color of the four line and a text
together. do you know how to change the color of block rather than change the
color of each individual )
another question is that
if the colors of rect is changed , the near line color will be changed. do
you know how to check whether the line touch the rect or not ?
Thanks.
wingame82
Date: 2012-12-20 19:24
To: [hidden email]
Subject: Re: How could I fetch the block and entity information
? First, read my comment:  http://forum.librecad.org/Block-can-not-be-inserted-on-different-layers-td5544026.html#a5544807 If you want to write a plugin, you can modify a bit "list plugin" and you have what you need. If you reply to this email, your message will be
added to the discussion below: http://forum.librecad.org/How-could-I-fetch-the-block-and-entity-information-tp5707314p5707315.html
To
start a new topic under LibreCAD-dev, email
[hidden email]  To unsubscribe from How could I fetch the block and entity information ?, click here. NAML  |
				In reply to this post by Johnson
		Hi Johnson,
				by parts... Is Ok, I do not see any problem. Ckecking Xline - Xinsert < 1e5 etc. is easy. The problem is that access to the boundary of "block definition" is not implemented in plugins (you can implement it and send a patch :-) ) A "block" (block definition) is the same as a document or drawing (entity container) A "insert" is a entity, a reference to "block" (block definition) when you add a block in the drawing you are adding an "insertion" (like a C pointer) If you change the color of the entities which form the block, then all inserts change =>BAD A "insert" is a entity with color, linetype etc. if you change the color of the "insert" only this "insert" change the color => GOOD The problem (and the solution) is On draw a "insert" the sequence are: red insert -> black line in "block" -> draw a black line red insert -> bylayer line in "block" -> line in yelow layer -> draw a yelow line red insert -> byblock line in "block" -> insert is red -> draw a red line and... bylayer insert -> byblock line in "block" -> insert in blue layer -> draw a blue line That is, a powerful "block definition" have all the entities in layer 0 & color, linetype & width "byblock" Attached a dxf to demostrate. check "sameprop plugin" (Edit->Same properties) this plugin changes layer, color, linetype & width. Rallaz  |
	Thanks very much .Rallaz
I will try that and will let you know the result . Thanks again !
wingame82
Date: 2012-12-21 03:14
To: [hidden email]
Subject: Re: Re: How could I fetch the block and entity
information ? Hi Johnson,  by parts... Is Ok, I do not see any problem. Ckecking Xline - Xinsert < 1e5 etc. is easy. The problem is that access to the boundary of "block definition" is not implemented in plugins (you can implement it and send a patch :-) ) A "block" (block definition) is the same as a document or drawing (entity container) A "insert" is a entity, a reference to "block" (block definition) when you add a block in the drawing you are adding an "insertion" (like a C pointer) If you change the color of the entities which form the block, then all inserts change =>BAD A "insert" is a entity with color, linetype etc. if you change the color of the "insert" only this "insert" change the color => GOOD The problem (and the solution) is On draw a "insert" the sequence are: red insert -> black line in "block" -> draw a black line red insert -> bylayer line in "block" -> line in yelow layer -> draw a yelow line red insert -> byblock line in "block" -> insert is red -> draw a red line and... bylayer insert -> byblock line in "block" -> insert in blue layer -> draw a blue line That is, a powerful "block definition" have all the entities in layer 0 & color, linetype & width "byblock" Attached a dxf to demostrate. check "sameprop plugin" (Edit->Same properties) this plugin changes layer, color, linetype & width. Rallaz If you reply to this email, your message will be
added to the discussion below: http://forum.librecad.org/How-could-I-fetch-the-block-and-entity-information-tp5707314p5707318.html
To
