I can draw on layers that are not visible
2 messages Options Options
Hans-Werner
Re: I can draw on layers that are not visible
Hans,
I just tried this on QCad version and I could do the same.
This looks like heritage of the QCad CE code. I agree it doesn't make
a hole lot sense why this was created like that…. we can only guess.
If you like to have this changed, you can put a bug report on here:
or
Ries
On Mar 3, 2012, at 5:16 PM, Hans-Werner [via LibreCAD] wrote:
As I found out I can draw on layers that are not visible.
What is the idea behind that ?
Why can I set a layer active that is not visible ?
http://forum.librecad.org/I-can-draw-on-layers-that-are-not-visible-tp5534459p5534459.html
