Hi Armin, thanks a lot of your kind info. I have tried, both are working. The #907 and #1035 are very helping. But got confuse regarding the command " z" and " e" in #907. I always got error regarding the two as below:
z
Unknown command: z
e
Unknown command: e
What is the meaning of the two commands? When I deleted both them, no more error at all.
Here are the data I used to plot a mathematical expression: y(t)=e^-t*cos(2*pi*t): That will plot a line following the coordinates. The first command (l-line), I replaced with pl-polyline and spline, they are both working well. So do those testing working well when I tested for " Load Command File" and " Paste Multiple Commands".
For this testing, the data below I did in Excel. Then I saved to Notepad to run " Load Command File", and thence I copied and pasted to the command line to run " Paste Multiple Commands".
l;
0,2.5;
0.1,1.8300721208436;
0.2,0.632504291296238;
0.3,-0.572313549833152;
0.4,-1.35575077228257;
0.5,-1.51632664928158;
0.6,-1.10999485077697;
0.7,-0.383633245070979;
0.8,0.347125714942781;
0.9,0.822304410318461;
1,0.919698602928606;
1.1,0.673245909119379;
1.2,0.232685325220599;
1.3,-0.210542388887464;
1.4,-0.498752836475064;
1.5,-0.557825400371075;
1.6,-0.408344285407009;
1.7,-0.141130783811499;
1.8,0.127700414029388;
1.9,0.302508886940768;
2,0.338338208091532;
2.1,0.247673328817797;
2.2,0.085600147410949;
2.3,-0.0774542163668204;
2.4,-0.183480914765118;
2.5,-0.205212496559747;
2.6,-0.150221467521082;
2.7,-0.0519191138806619;
2.8,0.0469783569504929;
2.9,0.111286800277165;
3,0.12446767091966;
3.1,0.0911139257985621;
3.2,0.0314905343937332;
3.3,-0.028493813833398;
3.4,-0.0674988563894168;
3.5,-0.0754934585557963;
3.6,-0.0552633895236098;
3.7,-0.0190999746005344;
3.8,0.0172823717020998;
3.9,0.0409401258957213;
4,0.0457890972218354;
4.1,0.0335189401057114;
4.2,0.0115847201949567;
4.3,-0.0104822883098736;
4.4,-0.0248314415682501;
4.5,-0.0277724913456058;
4.6,-0.0203302648551854;
4.7,-0.00702648798243333;
4.8,0.00635782924388563;
4.9,0.0150610306360065;
5,0.0168448674977137;
Best regard,
