Layer changes on trimming, bug or feature?
in a drawing are multiple layers, the yellow layer is the active on. When I trim the circle on the green layer, the trimmed entity is moved to the active layer. I have expected, that the layer of the trimmed entity is kept untouched.
Is this behaviour a feature by design or a bug?
CT
Re: Layer changes on trimming, bug or feature?
CT
This would be a bug!
claus82
I use the version 2 and up to now I did not have this kind of behaviour...
Probably its's a bug as Gooey says
I'm curious tough!
Bye
Cla
I do see a bug is the line attributes in drawing preview.
The preview entities should be drawn by black/white, instead of by another layer in color.
On Thu, Oct 24, 2013 at 10:35 AM, claus82 [via LibreCAD] <[hidden email]> wrote:
I use the version 2 and up ro now I did not have this kind of behaviour...
I'm curious tough!
Bye
Cla
http://forum.librecad.org/Layer-changes-on-trimming-bug-or-feature-tp5709060p5709064.html
Dongxu Li, Ph.D.
www.librecad.org
