LibreCad Crashes When Opening File
75 messages Options
1234
Re: Update on LibreCad Crashes When Opening File
cantcode
sorry, zip should work.
http://www.gamefront.com/files/23535096/lcad_cantcode_i586.zip
md5sum /home/me/Downloads/lcad_cantcode_i586.zip   should tell:
f7ef00e6cb387e3c91febb99fd9be0d4  lcad_cantcode_i586.zip
ozcad
I have just upgraded to openSUSE 12.3.
It was done as an upgrade rather than a clean wipe and re-install, because it takes so long to restore the system to be the way it was.
This may have been a mistake.
I then installed the proffered file:
A test run with gdb follows.
jim@linux-jim:~> gdb librecad
GNU gdb (GDB) SUSE (7.5.1-2.1.1)
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "i586-suse-linux".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /usr/bin/librecad...Reading symbols from /usr/lib/debug/usr/bin/librecad.debug...done.
done.
(gdb) run
Starting program: /usr/bin/librecad
Missing separate debuginfo for /lib/ld-linux.so.2
Try: zypper install -C "debuginfo(build-id)=d63d9a9ac674ed30093eb2f92fec0c1aebb9dd3b"
Missing separate debuginfo for /usr/lib/libmuparser.so.2
Try: zypper install -C "debuginfo(build-id)=ad5db190f6743e35c26b6ab14cd7b512a9a4fc45"
Missing separate debuginfo for /usr/lib/libQtHelp.so.4
Try: zypper install -C "debuginfo(build-id)=ff994ccf99659406fc56ad6999324cb2a032c700"
Missing separate debuginfo for /usr/lib/libQtNetwork.so.4
Try: zypper install -C "debuginfo(build-id)=6b36d34496335fff455e362abf87b5a538ef8325"
Missing separate debuginfo for /usr/lib/libQtSvg.so.4
Try: zypper install -C "debuginfo(build-id)=3a1e1acac37dd1509a14f5c9b963093febfff26e"
Missing separate debuginfo for /usr/lib/libQtSql.so.4
Try: zypper install -C "debuginfo(build-id)=eccf606e0c4af0ab4eedb93e53adc0a12124c9c9"
Missing separate debuginfo for /usr/lib/libQtGui.so.4
Try: zypper install -C "debuginfo(build-id)=99d66ab1412a2b81374604ca368b3f7cc9845ff0"
Missing separate debuginfo for /usr/lib/libQtCore.so.4
Try: zypper install -C "debuginfo(build-id)=d623a1cee58a08790b6d6470827470f5bf29f23f"
Missing separate debuginfo for /lib/libpthread.so.0
Try: zypper install -C "debuginfo(build-id)=23df54dff712ba767fab638c8e5ce5b8aa4b48d5"
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/libthread_db.so.1".
Missing separate debuginfo for /usr/lib/libstdc++.so.6
Try: zypper install -C "debuginfo(build-id)=bd11ef0114f076d915da9a87ffd3bf0e2f64a328"
Missing separate debuginfo for /lib/libm.so.6
Try: zypper install -C "debuginfo(build-id)=f3e94965d133ebf34e3196bef9f8dc42ec7a7783"
Missing separate debuginfo for /lib/libgcc_s.so.1
Try: zypper install -C "debuginfo(build-id)=8e8302a9033ceb3a5beeff9690b98d1e2fba5f0a"
Missing separate debuginfo for /lib/libc.so.6
Try: zypper install -C "debuginfo(build-id)=f8dbffc0f35eee7e109942e231aaf29aa6bbb96e"
Missing separate debuginfo for /usr/lib/libQtCLucene.so.4
Try: zypper install -C "debuginfo(build-id)=eab9c76e8f235030990b337edb65512775e825d2"
Missing separate debuginfo for /lib/libz.so.1
Try: zypper install -C "debuginfo(build-id)=bb2b5baf7a8808c31a5d5aa8355d548b3540d152"
Missing separate debuginfo for /lib/libssl.so.1.0.0
Try: zypper install -C "debuginfo(build-id)=27a181af8b34aaf5ea0537799f2a20dc754303e2"
Missing separate debuginfo for /lib/libcrypto.so.1.0.0
Try: zypper install -C "debuginfo(build-id)=4372a84da7c3b833b09e6fe1dc15649a4d64033d"
Missing separate debuginfo for /usr/lib/libglib-2.0.so.0
Try: zypper install -C "debuginfo(build-id)=c57e29f9a1116ab42741997a64328a035c02c19c"
Missing separate debuginfo for /usr/lib/libpng15.so.15
Try: zypper install -C "debuginfo(build-id)=ed21d272f76cee71fbf7cd6389fb0f827db719c5"
Missing separate debuginfo for /usr/lib/libfreetype.so.6
Try: zypper install -C "debuginfo(build-id)=797279d430d8fd385989686bf14ea28d7a004786"
Missing separate debuginfo for /usr/lib/libgobject-2.0.so.0
Try: zypper install -C "debuginfo(build-id)=188dfc54277cb2b00667bb51a02f858fa6486c61"
Missing separate debuginfo for /usr/lib/libSM.so.6
Try: zypper install -C "debuginfo(build-id)=8c4f6c176c49b85c2c1dabe28c35d96aeeb8a374"
Missing separate debuginfo for /usr/lib/libICE.so.6
Try: zypper install -C "debuginfo(build-id)=c63006faf83a7dd14647cad3bede2a1c3b394fdd"
Missing separate debuginfo for /usr/lib/libXi.so.6
Try: zypper install -C "debuginfo(build-id)=a95a567ef3d8cd748bfd59ec4cc236b3886dee11"
Missing separate debuginfo for /usr/lib/libXrender.so.1
Try: zypper install -C "debuginfo(build-id)=5f4110824602fbf3e232062568d14d68b265307d"
Missing separate debuginfo for /usr/lib/libXrandr.so.2
Try: zypper install -C "debuginfo(build-id)=9c8ed7253f9a3465d3fd64f8c9cd13f6e88e4fd5"
Missing separate debuginfo for /usr/lib/libXfixes.so.3
Try: zypper install -C "debuginfo(build-id)=95bf8a5e4f46101fec70128a920fec029dae9418"
Missing separate debuginfo for /usr/lib/libXcursor.so.1
Try: zypper install -C "debuginfo(build-id)=8b169dc78072719b8bf56ea487bec1fed5443a63"
Missing separate debuginfo for /usr/lib/libXinerama.so.1
Try: zypper install -C "debuginfo(build-id)=6e6324a5450bf0ceb9df9fd9cd8eae6af71b2a8d"
Missing separate debuginfo for /usr/lib/libfontconfig.so.1
Try: zypper install -C "debuginfo(build-id)=3e6e229bbe584a0f7467b87b2cc6070b09d0a646"
Missing separate debuginfo for /usr/lib/libXext.so.6
Try: zypper install -C "debuginfo(build-id)=6ad30f5263aeb2a99ecb5e9feb16ab9e20a23092"
Missing separate debuginfo for /usr/lib/libX11.so.6
Try: zypper install -C "debuginfo(build-id)=fb4c177d543c6e6ecb3919519833cf2ab3b9796c"
Missing separate debuginfo for /lib/libdl.so.2
Try: zypper install -C "debuginfo(build-id)=415b87a04594869200b17966883c747bf7a198b4"
Missing separate debuginfo for /lib/librt.so.1
Try: zypper install -C "debuginfo(build-id)=cde95b358e424c7efd6662b454e8d516ab5340c9"
Missing separate debuginfo for /usr/lib/libpcre.so.1
Try: zypper install -C "debuginfo(build-id)=ba9ff1cf924c19d7875749d42378da6569a48fb0"
Missing separate debuginfo for /usr/lib/libffi.so.4
Try: zypper install -C "debuginfo(build-id)=7bdd092fe0e36f65afa36e565a723cf12e18930d"
Missing separate debuginfo for /usr/lib/libuuid.so.1
Try: zypper install -C "debuginfo(build-id)=b7d4924d31c0fa19db85c281841e8fe9092b409a"
Missing separate debuginfo for /usr/lib/libexpat.so.1
Try: zypper install -C "debuginfo(build-id)=91a120cbeaeb971ad17ff9d034a0fa3c6a6cf35a"
Missing separate debuginfo for /usr/lib/libxcb.so.1
Try: zypper install -C "debuginfo(build-id)=f29787f4cd47e6bb3d195c87145e7aa2483df8c9"
Missing separate debuginfo for /usr/lib/libXau.so.6
Try: zypper install -C "debuginfo(build-id)=96ecc373e0f886a2d2e81386ba45c69336c01253"
Missing separate debuginfo for /usr/lib/gconv/UTF-16.so
Try: zypper install -C "debuginfo(build-id)=1e23c78449a54b92bfdf4cf00be30887ac87bc15"
Fontconfig warning: "/etc/fonts/conf.d/56-user.conf", line 9: reading configurations from ~/.fonts.conf is deprecated.
Missing separate debuginfo for /usr/lib/kde4/plugins/gui_platform/libkde.so
Try: zypper install -C "debuginfo(build-id)=81ede24cfa7f88190730a052c57d707d888b215a"
Missing separate debuginfo for /usr/lib/libkio.so.5
Try: zypper install -C "debuginfo(build-id)=6ffa065d58148fc89be9ee3c61cb9f5d220ef9a7"
Missing separate debuginfo for /usr/lib/libkdeui.so.5
Try: zypper install -C "debuginfo(build-id)=6ea5252e04eebcc7bda1570315e99c7a00937050"
Missing separate debuginfo for /usr/lib/libkdecore.so.5
Try: zypper install -C "debuginfo(build-id)=220ba9df2ee0b361cef1a5027c00731e60783484"
Missing separate debuginfo for /usr/lib/libnepomuk.so.4
Try: zypper install -C "debuginfo(build-id)=d779c0bf93b01e34f869df577fbf2354590cb82e"
Missing separate debuginfo for /usr/lib/libQtXml.so.4
Try: zypper install -C "debuginfo(build-id)=23968451250f5f4536d85d107f13a78a0a81013d"
Missing separate debuginfo for /usr/lib/libstreamanalyzer.so.0
Try: zypper install -C "debuginfo(build-id)=a7d1f0070d2885506ffaa58511e52069225f4b56"
Missing separate debuginfo for /usr/lib/libsolid.so.4
Try: zypper install -C "debuginfo(build-id)=7e41b7c9e60211853b9efa62a36a37818c358d35"
Missing separate debuginfo for /usr/lib/libksuseinstall.so.1
Try: zypper install -C "debuginfo(build-id)=6c4130896a4651ee6fa744bdd02801ecc45fbf54"
Missing separate debuginfo for /lib/libacl.so.1
Try: zypper install -C "debuginfo(build-id)=6849eec17eb665b36b1751dd2f1ee1d53010f344"
Missing separate debuginfo for /lib/libattr.so.1
Try: zypper install -C "debuginfo(build-id)=b08be0171fe7b92b000242248685e28c2d02d60a"
Missing separate debuginfo for /usr/lib/libQtDBus.so.4
Try: zypper install -C "debuginfo(build-id)=824401218eb31089dada428cd699c80008235693"
Missing separate debuginfo for /usr/lib/libattica.so.0.4
Try: zypper install -C "debuginfo(build-id)=e5893ffb17b23f473e951e988697817859f50541"
Missing separate debuginfo for /usr/lib/libdbusmenu-qt.so.2
Try: zypper install -C "debuginfo(build-id)=5106372a780a9ce9a71c1ed352eb75712438c33d"
Missing separate debuginfo for /usr/lib/libXtst.so.6
Try: zypper install -C "debuginfo(build-id)=d16f1e73ac2dd179e1a4e00414dd7979e1048371"
Missing separate debuginfo for /usr/lib/libbz2.so.1
Try: zypper install -C "debuginfo(build-id)=70c2d220bc3b4e480154704d4df9027519a6815a"
Missing separate debuginfo for /usr/lib/liblzma.so.5
Try: zypper install -C "debuginfo(build-id)=9bad1635221b46f9d88b8dbb942101d641f43cf1"
Missing separate debuginfo for /usr/lib/libfam.so.0
Try: zypper install -C "debuginfo(build-id)=b9e6c29de1c59d277809a84aed8670eac0d8055e"
Missing separate debuginfo for /usr/lib/libsoprano.so.4
Try: zypper install -C "debuginfo(build-id)=29e979bffb0aa9eb533b97d11e3be4362e8e5e5a"
Missing separate debuginfo for /usr/lib/libsopranoclient.so.1
Try: zypper install -C "debuginfo(build-id)=c943e3208f81e3ff4873f40cbe6e0c22c7493088"
Missing separate debuginfo for /usr/lib/libstreams.so.0
Try: zypper install -C "debuginfo(build-id)=98e29c8c1a380ecafe787c051e0ed8a3c3b78161"
Missing separate debuginfo for /usr/lib/libxml2.so.2
Try: zypper install -C "debuginfo(build-id)=f783b04837f5a072f5adf13603632b728d20163d"
Missing separate debuginfo for /usr/lib/libudev.so.1
Try: zypper install -C "debuginfo(build-id)=4e2ae220a559394c9efbbade858e7fd50e306bf0"
Missing separate debuginfo for /lib/libdbus-1.so.3
Try: zypper install -C "debuginfo(build-id)=e75e4173b0681e796783ec19a5f942451e4348ff"
Missing separate debuginfo for /usr/lib/kde4/plugins/styles/oxygen.so
Try: zypper install -C "debuginfo(build-id)=5e813b9c451062ab4198120fa11c6f4bcb8f0c65"
Missing separate debuginfo for /usr/lib/liboxygenstyle.so.4
Try: zypper install -C "debuginfo(build-id)=9404f2e388a069846b2e8fbde99bcbc472980ef8"
Missing separate debuginfo for /usr/lib/qt4/plugins/imageformats/libqgif.so
Try: zypper install -C "debuginfo(build-id)=2997671f715d7da17e1ddab12b46a3a22a8620ee"
Missing separate debuginfo for /usr/lib/qt4/plugins/imageformats/libqico.so
Try: zypper install -C "debuginfo(build-id)=cd52bbaef57f04bddbde230f1121b18c8615a8a5"
Missing separate debuginfo for /usr/lib/qt4/plugins/imageformats/libqjpeg.so
Try: zypper install -C "debuginfo(build-id)=e46abec049de24be0d4f4e60812bf6fb96d4ac20"
Missing separate debuginfo for /usr/lib/libjpeg.so.8
Try: zypper install -C "debuginfo(build-id)=a24c2d42b39593583506d1484c4db7f3d82aa4b7"
Missing separate debuginfo for /usr/lib/qt4/plugins/imageformats/libqmng.so
Try: zypper install -C "debuginfo(build-id)=8538e8f799e4d60c05f467d68235dcabfa8fe249"
Missing separate debuginfo for /usr/lib/libmng.so.1
Try: zypper install -C "debuginfo(build-id)=3408a5ebd26de05d0ebe32ab03543c00e397aaf0"
Missing separate debuginfo for /usr/lib/liblcms.so.1
Try: zypper install -C "debuginfo(build-id)=6a6d7815eadddf96e2468d75fe1b15fd716c72c5"
Missing separate debuginfo for /usr/lib/qt4/plugins/imageformats/libqsvg.so
Try: zypper install -C "debuginfo(build-id)=a1fc0a22fb34000570e7853f8a724d4ffab2aae7"
Missing separate debuginfo for /usr/lib/qt4/plugins/imageformats/libqtga.so
Try: zypper install -C "debuginfo(build-id)=6ba99cce7a5ba730a65b7d83531e5451a2cd98f4"
Missing separate debuginfo for /usr/lib/qt4/plugins/imageformats/libqtiff.so
Try: zypper install -C "debuginfo(build-id)=aafffd020d07d74c67d3420fae0bce4740f049a1"
Missing separate debuginfo for /usr/lib/libtiff.so.5
Try: zypper install -C "debuginfo(build-id)=e4df4aeab88e7e4364553992f8c5707a7239a3b9"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_dds.so
Try: zypper install -C "debuginfo(build-id)=5f5c0a7426fa16bd6c2d7c6f639ea9e785cf5597"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_eps.so
Try: zypper install -C "debuginfo(build-id)=40c3e8c1c1ede2e32f938d8575a3b2296fa8d852"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_exr.so
Try: zypper install -C "debuginfo(build-id)=3bbea4bbe2947689ae7b2450ebaf3a076dfb5cd6"
Missing separate debuginfo for /usr/lib/libIlmImf.so.7
Try: zypper install -C "debuginfo(build-id)=0596eede13b1f666e1b8e0fa6b54abda3a991c0c"
Missing separate debuginfo for /usr/lib/libIex.so.7
Try: zypper install -C "debuginfo(build-id)=fac0de863fe369f475bb2d563833fb1ea6c11b7e"
Missing separate debuginfo for /usr/lib/libHalf.so.7
Try: zypper install -C "debuginfo(build-id)=223373ff79a4eac490ff873d403efca327219fdd"
Missing separate debuginfo for /usr/lib/libIlmThread.so.7
Try: zypper install -C "debuginfo(build-id)=9516846468079c175b4e47683aadeb25c93329b5"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_jp2.so
Try: zypper install -C "debuginfo(build-id)=60731c7a891f0b316820fdf35236539e4c49622a"
Missing separate debuginfo for /usr/lib/libjasper.so.1
Try: zypper install -C "debuginfo(build-id)=b791ecdae7e6740f35632c875ef61193c005d13e"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_pcx.so
Try: zypper install -C "debuginfo(build-id)=347ce5d2459a38c269d11a6a41b361a95b294a24"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_pic.so
Try: zypper install -C "debuginfo(build-id)=e16d3b84dcde1d5f9f95aab9083e76d6fcd2a393"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_psd.so
Try: zypper install -C "debuginfo(build-id)=8f403aac3a2e3bdb40f1f463e17cf41a4f454b75"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_ras.so
Try: zypper install -C "debuginfo(build-id)=5da297f3e5234d56d1f09f0557187459faf1695d"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_rgb.so
Try: zypper install -C "debuginfo(build-id)=b4d51658d40a44611ea60fd3998dcc5f37139cc6"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_tga.so
Try: zypper install -C "debuginfo(build-id)=81e8edd06171452970b5856e21c5621533dfb2a9"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_xcf.so
Try: zypper install -C "debuginfo(build-id)=3cbcb3ad9a3fb8cfc85c475a2f9aeb80828d3de3"
Missing separate debuginfo for /usr/lib/kde4/plugins/imageformats/kimg_xview.so
Try: zypper install -C "debuginfo(build-id)=65d8ba05c5f3dc02e8edae5de4c347b1c7509d56"
Missing separate debuginfo for /lib/libnss_compat.so.2
Try: zypper install -C "debuginfo(build-id)=cd5ea9aacbb0e925e17c687f3ec48f6bc0cd3063"
Missing separate debuginfo for /lib/libnsl.so.1
Try: zypper install -C "debuginfo(build-id)=5089c2f98b48f44cc6c3567b9d1d7f635e9d3f1c"
Missing separate debuginfo for /lib/libnss_nis.so.2
Try: zypper install -C "debuginfo(build-id)=8f60d11485b30829d9095db72cc631abee7bb00e"
Missing separate debuginfo for /lib/libnss_files.so.2
Try: zypper install -C "debuginfo(build-id)=8d77c67c244180e892d9b57ecdacf00eb6d7a33c"
Missing separate debuginfo for /usr/lib/qt4/plugins/menubar/libappmenu-qt.so
Try: zypper install -C "debuginfo(build-id)=e85729d01ecb2f84ea990f9263dad3f767cbb099"
^C
Program received signal SIGINT, Interrupt.
0xb6c683de in __poll_nocancel () from /lib/libc.so.6
(gdb) Q
A debugging session is active.
        Inferior 1 [process 24903] will be killed.
Quit anyway? (y or n) Y
jim@linux-jim:~>
It is looking to me as if the problem has nothing to do with you guys.
I may in fact need to do a clean wipe and install.  I must defer that step as I am in the middle of a job and cannot afford to risk downtime.  The Windows version under Wine continues to work well.  I hope you got my "encouragement" donation.  It is a nice program.  I will be back.  Thank you.
cantcode
Looks like we have a different output.
old output:
[New Thread 0xb2bffb40 (LWP 12144)]
Program received signal SIGSEGV, Segmentation fault.
0xb6faf44f in ?? () from /usr/lib/libstdc++.so.6
new output:
^C
Have you done the same steps as before?
To me it looks like you tried to copy the text from the terminal using Ctrl+C and stopped librecad/gdb.
(Cause it looks the same when I do this everytime)
Can you please try to run/crash it again and see if you get the same output?
"I have just upgraded to openSUSE 12.3. "
So the last time you posted the output (old output) you used 12.2 and now (new output) you are using 12.3?
Another thing you could try, is instead of quitting gdb after the crash you could try to type bt (it's just a small b and a small t without any space) and hit enter and post the output.
If you have no time to investigate the behaviour, due to your job please tell.
ozcad
Experiment:
I re-installed an old version
    libdxfrw0-0.5.4-1.1.i386.rpm
    librecad-2.0.0beta1-1.1.i586.rpm
    librecad-parts-2.0.0beta1-1.1.noarch.rpm
It can load the example files (t-part.dxf), but not save them.  A gdb run follows.
Reading symbols from /usr/bin/librecad...(no debugging symbols found)...done.
(gdb) run
<<<<<<<<<<<<<< LibreCAD now ready for user input
<<<<<<<<<<<<<< Menu -> FIle -> Open -> t-part.dxf
[New Thread 0xb3426b40 (LWP 8081)]
[New Thread 0xb2affb40 (LWP 8082)]
[Thread 0xb3426b40 (LWP 8081) exited]
[Thread 0xb2affb40 (LWP 8082) exited]
<<<<<<<<<<<<<< File correctly loaded & displayed
<<<<<<<<<<<<<< Menu -> File -> Save as... -> junk4.dxf
[New Thread 0xb2affb40 (LWP 8083)]
[New Thread 0xb3426b40 (LWP 8084)]
$ACADVER
0xb6fa1dda in ?? () from /usr/lib/libstdc++.so.6
(gdb)
(gdb) bt
#0  0xb6fa1dda in ?? () from /usr/lib/libstdc++.so.6
#1  0xb6fa34d5 in std::string::_M_mutate(unsigned int, unsigned int, unsigned int) () from /usr/lib/libstdc++.so.6
#2  0xb6fa3532 in std::string::_M_replace_safe(unsigned int, unsigned int, char const*, unsigned int) () from /usr/lib/libstdc++.so.6
#3  0xb6fa35db in std::string::assign(char const*, unsigned int) () from /usr/lib/libstdc++.so.6
#4  0xb7f16428 in assign (__s=0xbfffd6ab "49", this=0xbfffd73c) at /usr/include/c++/4.7/bits/basic_string.h:1128
#5  operator= (__s=0xbfffd6ab "49", this=0xbfffd73c) at /usr/include/c++/4.7/bits/basic_string.h:552
#6  dxfRW::writeEntity (this=this@entry=0x90e97e0, ent=ent@entry=0xbfffd734) at src/libdxfrw.cpp:153
#7  0xb7f1935b in dxfRW::writeLine (this=0x90e97e0, ent=0xbfffd734) at src/libdxfrw.cpp:507
#8  0x08124c46 in ?? ()
#9  0x0813614a in ?? ()
#10 0xb7f28428 in dxfRW::write (this=0x90e97e0, interface_=0x88e1aac, ver=DRW::AC1021, bin=false) at src/libdxfrw.cpp:132
#11 0x0811ea75 in ?? ()
#12 0x0811b1d4 in ?? ()
#13 0x080c9d72 in ?? ()
#14 0x080c860d in ?? ()
#15 0x08327d41 in ?? ()
#16 0x08316ee6 in ?? ()
#17 0x0834e157 in ?? ()
#18 0xb717d535 in QMetaObject::metacall(QObject*, QMetaObject::Call, int, void**) () from /usr/lib/libQtCore.so.4
#19 0xb718ef8f in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/libQtCore.so.4
#20 0xb742bb4d in QAction::triggered(bool) () from /usr/lib/libQtGui.so.4
#21 0xb742bdec in QAction::activate(QAction::ActionEvent) () from /usr/lib/libQtGui.so.4
#22 0xb78de555 in ?? () from /usr/lib/libQtGui.so.4
#23 0xb78e5716 in ?? () from /usr/lib/libQtGui.so.4
#24 0xb78e6675 in QMenu::mouseReleaseEvent(QMouseEvent*) () from /usr/lib/libQtGui.so.4
#25 0xb748c8b4 in QWidget::event(QEvent*) () from /usr/lib/libQtGui.so.4
#26 0xb78e6b6c in QMenu::event(QEvent*) () from /usr/lib/libQtGui.so.4
#27 0xb7432bac in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/libQtGui.so.4
#28 0xb7438081 in QApplication::notify(QObject*, QEvent*) () from /usr/lib/libQtGui.so.4
#29 0xb71768ce in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib/libQtCore.so.4
#30 0xb7433a0f in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from /usr/lib/libQtGui.so.4
---Type <return> to continue, or q <return> to quit---
#31 0xb74bc03f in ?? () from /usr/lib/libQtGui.so.4
#32 0xb74bac59 in QApplication::x11ProcessEvent(_XEvent*) () from /usr/lib/libQtGui.so.4
#33 0xb74e48c4 in ?? () from /usr/lib/libQtGui.so.4
#34 0xb69d28b3 in g_main_context_dispatch () from /usr/lib/libglib-2.0.so.0
#35 0xb69d2c50 in ?? () from /usr/lib/libglib-2.0.so.0
#36 0xb69d2d31 in g_main_context_iteration () from /usr/lib/libglib-2.0.so.0
#37 0xb71a88af in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#38 0xb74e44aa in ?? () from /usr/lib/libQtGui.so.4
#39 0xb717539c in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#40 0xb7175691 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#41 0xb717a94a in QCoreApplication::exec() () from /usr/lib/libQtCore.so.4
#42 0xb7430a24 in QApplication::exec() () from /usr/lib/libQtGui.so.4
#43 0x0806a559 in ?? ()
#44 0xb6d2d525 in __libc_start_main () from /lib/libc.so.6
#45 0x0806d311 in ?? ()
(gdb) q
        Inferior 1 [process 8076] will be killed.
Quit anyway? (y or n) y
jim@linux-jim:~>
Remember, this is an old version, which might limit the relevance.
I will update to latest LibreCAD technology & try again.
ozcad
Updating to latest smarts from your downloads page
    http://librecad.org/cms/home/installation/rpm-packages.html
Returns us to the condition of "crash on Open" and "crash on Save as..."
BTW, on your RPM packages page at
...there seems to be an "Error 404 Not Found" for most of the 32-bit "libdxfrw0.5.9" RPMs.
I hope there is no unscheduled problem for you.
cantcode
Seems like we made a step forward.
"I re-installed an old version
    librecad-parts-2.0.0beta1-1.1.noarch.rpm "
have you also uninstalled/installed a different version of:
librecad-debuginfo
libdxfrw0-debuginfo
or did you use these:
librecad-debuginfo-2.0.0rc1.git20130625-2.1.i586.rpm
libdxfrw0-debuginfo-0.5.9-1.1.i586.rpm
which debuginfo packages do you have now?
"#6  dxfRW::writeEntity (this=this@entry=0x90e97e0, ent=ent@entry=0xbfffd734) at src/libdxfrw.cpp:153
#7  0xb7f1935b in dxfRW::writeLine (this=0x90e97e0, ent=0xbfffd734) at src/libdxfrw.cpp:507 "
So the error/crash should be caused by the file libdxfrw.cpp.
To verify this could you please install  libdxfrw0-0.5.4-1.1.i386.rpm over the version you have right now and see if you get
the same behaviour (opening should work, saving should crash)(using librecad-2.0.0rc1.git20130625-2.1.i586.rpm) . Then install the current version of libdxfrw. If Yast won't allow this just let it be.
Cause "bt" helped us to find the cause, could you also please try to use bt with all current versions of librecad?
libdxfrw0-0.5.9-1.1.i586.rpm
and post it here? (I know you also did this but without the bt command) (both, open and save)
"...there seems to be an "Error 404 Not Found" for most of the 32-bit "libdxfrw0.5.9" RPMs. "
works for me (can download libdxfrw0.5.9 for 12.2 and 12.3 32bit)
cantcode
Actually you do not have to do ALL the steps I told you. It should be enought to open a file with librecad and use bt (with current versions of librecad and libdxfrw).
This should be enough for the first step.
Could you please use http://forum.librecad.org/file/n5708482/mechtute4.dxf for opening (so you and I have the same file).
ozcad
Hi gize.
Humbly apologise for delay, I'm back with a few nano-eons to spare.
Uses  libdxfrw0  0.5.4-5.1.1
Uses librecad               2.0.0rc1.git20130625-2.1
        and librecad parts 2.0.0rc1.git20130625-2.1
Note mismatched debug info file complaints.
jim@linux-jim:/windows/D/CadCamCnc/LibreCAD/Testing> gdb librecad
(gdb) run
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Attempted to open "mechtute4.dxf" file here
[New Thread 0xb3487b40 (LWP 2995)]
[New Thread 0xb2affb40 (LWP 2996)]
0xb6fa229f in ?? () from /usr/lib/libstdc++.so.6
(gdb) bt
#0  0xb6fa229f in ?? () from /usr/lib/libstdc++.so.6
#1  0xb6fa3d98 in std::string::assign(std::string const&) () from /usr/lib/libstdc++.so.6
#2  0xb7f0ee02 in operator= (__str=..., this=<optimized out>) at /usr/include/c++/4.7/bits/basic_string.h:544
#3  DRW_TableEntry::parseCode (this=0xbfffd6a0, code=-12, reader=0x903e650) at src/drw_objects.cpp:27
#4  0xb7f0fec3 in DRW_Vport::parseCode (this=0xbfffd6a0, code=5, reader=0x903e650) at src/drw_objects.cpp:480
#5  0xb7f24576 in dxfRW::processVports (this=this@entry=0xbfffda68) at src/libdxfrw.cpp:1969
#6  0xb7f26a93 in dxfRW::processTables (this=this@entry=0xbfffda68) at src/libdxfrw.cpp:1826
#7  0xb7f29165 in dxfRW::processDxf (this=this@entry=0xbfffda68) at src/libdxfrw.cpp:1761
#8  0xb7f29406 in dxfRW::read (this=0xbfffda68, interface_=0x8d640a4, ext=true) at src/libdxfrw.cpp:87
#9  0x08118408 in ?? ()
#10 0x081154aa in ?? ()
#11 0x080c6312 in ?? ()
#12 0x0830ddf9 in ?? ()
#13 0x08307103 in ?? ()
#14 0x0830843d in ?? ()
#15 0x08333bcc in ?? ()
#16 0xb718dc22 in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/libQtCore.so.4
#17 0xb742ab4d in QAction::triggered(bool) () from /usr/lib/libQtGui.so.4
#18 0xb742adec in QAction::activate(QAction::ActionEvent) () from /usr/lib/libQtGui.so.4
#19 0xb78dd555 in ?? () from /usr/lib/libQtGui.so.4
#20 0xb78e4716 in ?? () from /usr/lib/libQtGui.so.4
#21 0xb78e5675 in QMenu::mouseReleaseEvent(QMouseEvent*) () from /usr/lib/libQtGui.so.4
#22 0xb748b8b4 in QWidget::event(QEvent*) () from /usr/lib/libQtGui.so.4
#23 0xb78e5b6c in QMenu::event(QEvent*) () from /usr/lib/libQtGui.so.4
---Type <return> to continue, or q <return> to quit---q
Quit
(gdb) q
        Inferior 1 [process 2990] will be killed.
Jim A.
cantcode
I appreciate your nano-eons.
Is the mechtute4.dxf file you are trying to open, somewhere in your home directory and not on a filesystem which is mounted through samba, ssh, whatever?
That's strange in the #3 line the variable "code" is -12 but in the #4 line it is 5 ???
Looking at the file drw_objects.cpp it should not change. Actually it has to be 5 to reach the line 27 in this file.
The line #7 also does not make much sense to me, because in line 1761 (file libdxfrw.cpp)  I can not find a call of processTables.
Maybe I don't have the source code (says 0.5.4) of the same version you have installed.
Because I did not expect the 0.5.4 version causing a crash when opening a file I think I will first try to install ALL packages you had installed on your machine and see if I can reproduce the crash.
Can you tell me if you installed some of the following packages manually?
cups-pdf
google-earth-stable
k3b-codecs
libdvdcss2
libdynamite0
libeigen3-devel
libmp4v2-1
libmpeg2convert0
libode1
libode-devel
liborange0
libx264-125
libx264-128
libx264-129
musescore
OCE-debuginfo
OCE-devel
OCE
OpenMOIV-devel
OpenMOIV
openSUSE-release-dvd
orange
wine-doors
wine-mono
I can't find this packages in the repositories.
Can you please do "zypper lr --export foo.repo" and post the created file foo.repo here?
(this will tell ALL the repositories you are using)
Things I found on the net you could try:
#Use: strace librecad  in the terminal to start librecad and see if it still crashes.
#type qtconfig in your terminal and hit enter -> a window should appear -> set the GUI Style to Plastique or something else and try to start librecad and see if it still crashes.
ozcad
Lines starting with an asterisk were probably installed by me. Sometimes one does not entirely know what has been installed during an update.
* cups-pdf
* google-earth-stable
k3b-codecs
* libdvdcss2
libdynamite0
* libeigen3-devel
* libmp4v2-1
libmpeg2convert0
* libode1
* libode-devel
* liborange0
libx264-125
libx264-128
libx264-129
* musescore
OCE-debuginfo
OCE-devel
OCE
OpenMOIV-devel
OpenMOIV
orange
*wine-doors
* wine-mono
foo.repo is attached
If you reply to this email, your message will be added to the discussion below: http://forum.librecad.org/LibreCad-Crashes-When-Opening-File-tp5708103p5708679.html
To unsubscribe from LibreCad Crashes When Opening File, click here.
foo.repo (3K) Download Attachment
cantcode
Ok, I added this repositories:
http://download.opensuse.org/repositories/multimedia:/musescore/openSUSE_12.2/multimedia:musescore.repo
http://download.opensuse.org/repositories/science/openSUSE_12.2/science.repo
http://download.opensuse.org/repositories/Emulators:/Wine/openSUSE_12.2/Emulators:Wine.repo
http://download.opensuse.org/repositories/Printing/openSUSE_12.2/Printing.repo
and got google-earth from:
http://www.google.de/intl/de/earth/download/ge/agree.html
and now I'm down to this package list:
k3b-codecs
libdvdcss2
libmp4v2-1 -> libmp4v2-2
libmpeg2convert0
libode1
libode-devel
libx264-125
libx264-128
libx264-129  ->libx264-135
I have a different version of libmp4v2 and libx264 and I was told, that the openSUSE-release-dvd packagesjust adds a readme file. So removing this packages from the list we get this:
k3b-codecs
libdvdcss2
libmpeg2convert0
libode1
libode-devel
Because this libs are not for Qt and development stuff I doubt they have some influence on Qt or LibreCAD.
(will try to find and install them if I have more time)
What about:
"Is the mechtute4.dxf file you are trying to open, somewhere in your home directory and not on a filesystem which is mounted through samba, ssh, whatever? "
and
"#Use: strace librecad  in the terminal to start librecad and see if it still crashes.
#type qtconfig in your terminal and hit enter -> a window should appear -> set the GUI Style to Plastique or something else and try to start librecad and see if it still crashes." ?
btw. from tomorrow on I'll be offline for about two weeks
ozcad
On Thu, 22 Aug 2013 03:05:41 AM you wrote:
What about:
Yes, it is.
and
See attached konsole chatter. It is 4.9 MBytes long. I can trim the middle if that is too big.
It still crashes.
Have a good time. Wish I was there.
If you reply to this email, your message will be added to the discussion below: http://forum.librecad.org/LibreCad-Crashes-When-Opening-File-tp5708103p5708682.html
KonsoleChatter.txt (4M) Download Attachment
cantcode
I added the vlc repo
http://download.videolan.org/pub/vlc/SuSE/12.2/ vlc-i586
and downgraded k3b to install the k3b-codecs package.
Now I have all the packages you also had without these:
libmp4v2-1
libx264-125
libx264-128
libx264-129
But LCad still does not crash.
Time  to chip the rust off your debug/trace skills.
Could you please install this versions:
librecad    2.0.0rc1.git20130625-1.1
libdxfrw0   0.5.9-1.1
And do those three steps and post the (three) created files:
#1
librecad --debug 2>LCadout.log
now open the mechtute4.dxf file to crash LCad
->should create LCadout.log
#2
gdb librecad
set logging on LCadgdb.txt
thread apply all bt full
run
-->now open the mechtute4.dxf file to crash LCad
bt
q
->should create LCadgdb.txt
#3
strace -s2000 -o LCadtrace librecad
->should create LCadtrace
ozcad
...<snip>
Change of plans...
I have bought a new PC, the old one is slated to be used for LinuxCNC.
I have installed LibreCAD-32 on the new PC:
Version: master
SCM Revision: 2.0.0beta5
Compiled on: 2012-Sep-12
...from openSUSE. Dang - KMail is lousing up font sizes (from Arial 9 down to Arial 7) and refuses to accept a new size. Oh well.
LibreCAD seemes to work quite well. I suspect that something was wounded on my system - not so much a program file code corruption as a system config settings/data corruption. This would mean that re-installing a package would not guarantee a clean restart.
I think you have earned another encouragement award, stand by.
Jim A
cantcode
"I have bought a new PC, the old one is slated to be used for LinuxCNC."
too easy
"Dang - KMail is lousing up font sizes (from Arial 9 down to Arial 7) and refuses to accept a new size."
I don't use KMail and don't get what you mean by "lousing up" but here is what I found after a quick search:
#"Turned out I had "use fixed width fonts" turned on. (And on my  system they don't contain the required chars.)"
#" i went an read it - and yes, if you use fixed width fonts, you're okay. that's why i didnt see the prob, since i only use fixed-width"
"...was wounded on my system - not so much a program file code corruption as a system config settings/data corruption"
I was also thinking about this (like old config files).
"...earned another encouragement award, stand by."
Yeah would be nice if you could post those three files.
Which version of libdxfrw0 are u using?
Wondering if http://forum.librecad.org/Version-2-0-0rc2-2-g8573398-MacOs-crashing-when-opening-file-tp5708724.html has something to do with your crashes.
1234
