Menu Bar not showing
William Acuna
My name is William and I just registered as a new user. Hello world. I am in Peru. South America!
Please would you help me?
Menu bar missing: File, edit, View, Select, Draw, Dimensions, Modify, etc, etc.
I have uninstalled and reinstalled libreCAD and problem continues. Somewhere I read to delete a file:
~/.config/LibreCAD/LibreCAD.conf  but I just don't know how to do it. I use ubuntu 14 in a portable laptop.
I entered sudo su and have access to root. But can't find .conf directory.
Thank you all.
Re: Menu Bar not showing
I'm not a linux crack. I have LibreCAD on Puppy Linux, which is quite different. Here .config is a hidden directory. I have to tell the file manager to show hidden files (and directories), by default it's off. Then there is .config/LibreCAD/LibreCAD.conf.
Hope this helps.
William Acuna
Thank you dellus for your answer. I will look into it. I appreciate it.
Hope this helps.
http://forum.librecad.org/Menu-Bar-not-showing-tp5716888p5716892.html
To unsubscribe from Menu Bar not showing, click here.
Confidentiality Note: This message and any attachments
may contain legally privileged and/or confidential information.
Any unauthorized disclosure, use or dissemination of this e-mail
message or its contents, either in whole or in part, is prohibited.
If you are not the intended recipient of this e-mail message,
kindly notify the sender and then destroy it.
