No Hatch
22 messages Options
12
mwh
No Hatch
mwh
I can't seem to get the Hatch function to work. The Hatch preview isn't working either.
After I go through the motions of trying to create a Hatch, the status bar reports that a Hatch was successfully created, but no hatch shows up in the drawing.
The strange thing is, if I click inside the area where the Hatch is supposed to be, something gets selected according to the 'Selected Entities' status bar at the bottom, but the appearance of the drawing window doesn't change at all.
I'm using version 1.0.0rc2 but I had the same problem with the previous version.
Windows 7 x64
Thanks
Re: No Hatch
ClaudeQC
Hello mwh,
On 26/08/2011 9:17, mwh [via LibreCAD] wrote:
 > I can't seem to get the Hatch function to work. The Hatch preview
 > isn't
 > working either.
 > After I go through the motions of trying to create a Hatch, the
 > status
 > bar reports that a Hatch was successfully created, but no hatch shows
 > up
 > in the drawing.
 > The strange thing is, if I click inside the area where the Hatch
 > is
 > supposed to be, something gets selected according to the 'Selected
 > Entities' status bar at the bottom, but the appearance of the
 > drawing
 > window doesn't change at all.
 > I'm using version 1.0.0rc2 but I had the same problem with the
 > previous
 > version.
 > Windows 7 x64
- Please, can you report this bug in the LibreCAD Sourceforge
   bug tracker.  Below, a link to that bug tracker:
- Also, could you provide us a drawing sample on which
   the bug can be reproduced.
   Remark: This drawing can be included in the bug tracker.
Claude
mwh
Re: No Hatch
mwh
Hello Claude,
I'll try to report this on the bug tracker right now, as per your request.
I'll include a screen shot of the drawing window here, and on the bug tracker.
mwh
Re: No Hatch
mwh
In reply to this post by ClaudeQC
I'm not familiar with the bug tracker, so I hope my post is OK.
https://sourceforge.net/tracker/?func=detail&aid=3398712&group_id=342582&atid=1433844
Re: No Hatch
Your post in bug tracker is OK.
You can make some test...
If the hatch is solid, it work?
If you change the pattern, work in preview? work in drawing?
If scaling the circle x10 and set the hatch scale to 1,  work in drawing?
I have no windows 7 and I can not prove myself
mwh
Re: No Hatch
mwh
No.
No. I tried several different patterns.
No.
mwh
Re: No Hatch
mwh
By the way, is there supposed to be a choice of colors if you want a 'solid' hatch?
Re: No Hatch
In reply to this post by mwh
Someone with Windows 7 but 32 bits can see if it works ?
so we are discarding possibilities...
Re: No Hatch
mwh
Re: No Hatch
mwh
AH HAH!
That did the trick.
R. van Twisk rides to the rescue.
Now could you please explain how or why that fixed the problem? What does the Draft button do? (I guess I need to read further in the manual.)
Speaking of the Manual, it didn't work on my computer in rc1, but it works now.
Re: No Hatch
mwh
Re: No Hatch
mwh
Thanks.
Do I need to head on over to the bug tracker and flush my post down the toilet or anything?
Re: No Hatch
Re: No Hatch
bobol68
Excuse me,
I tried to create new hatch, I saved them in the folder / usr / share / librecad / patterns but when I put them in the drawing can not see anything, not even in preview.
To add a new hatch I followed the guide of Claus82 http://forum.librecad.org/file/n5708305/hatches_tutorial.pdf
Thank you for reading
PS the "draft" is unchecked
Re: No Hatch
cantcode
I'm not sure but I think you can only make hatches out of "Lines" and "Arcs".
Could you please try if this works for you?
@devs
Is the 2.x version only able to create hatches from lines and arcs only?
Re: No Hatch
bobol68
I will try as soon as possible .... thank you very much
Re: No Hatch
bobol68
I'm sorry but I do not think I understand what you mean.
First of all I wanted to say that I use version 1.0.2 of LC on a Linux distribution.
So, I create a drawing with some intersecting lines and save the picture in the folder "/ usr / share / librecad / patterns" with extension dxf.
Then I open a new drawing in LC and create a circle that I want to fill with the hatch just created.
I select the pattern created in the input mask hatch, but can not see anything.
But then 'if I click in the circle I see a dotted line as if I had actually selected something.
But I also noticed that many of the pre-installed hatch do not work.
Maybe the problem is related to the LC version in use.
Re: No Hatch
cantcode
Could you please install the latest version of LibreCAD?
Looks like you are using OSx so you could try this: http://sourceforge.net/projects/librecad/files/OSX/2.0.0rc2/
if you have a different operation system please see here: http://librecad.org/cms/home/installation/windows.html
linux:http://librecad.org/cms/home/installation/linux.html
Re: No Hatch
bobol68
The version 1.0.2 is the latest one that offers me the package manager.
Re: No Hatch
cantcode
Which operating system do you have?
for suse/fedora you can try this packages: http://librecad.org/cms/home/installation/rpm-packages.html
the latest stable version is 1.0.3 and there is also a release candidate of the 2.0.0 version
I would suggest to try the 2.0.0 version although it's a release candidate.
I tried to create hatches on the 1.0.2 version and also have problems doing it.
12
