Open dwg file version 2010
humulus
Hi all,
I'm using the latest stable version 2.0.10 on Windows 7.
I understand that opening dwg files is still in development, so I tested a lot of different dwg's.
Most I have are no problem, but while opening some important ones I have, I get:
Opened dwg file version dwg version 2010.
error reading blocks in dwg file
Cannot open the file
Should I try the latest alpha version?
regards,
Ruud
Re: Open dwg file version 2010
Unfortunately the developer working on that disappeared last year.
humulus
Unfortunately I'm no developer
Found a post that mentioned the Teigha file converter.
I think I can use it as a workaround, converting my 2010 files to 2007 format.
