Rounding
8 messages Options
Rounding
eslavko
Hello...
I have trouble rounding arc with line.
In attached image 1 is shape without rounding.
in image 2 the right corner is rounded as I want
in image 3 I try to do same as in image 2 but got wrong result every time.
1
2
3
test.dxf
Re: Rounding
I have no trouble on rounding:
round.dxf
Are you running the latest release (2.0.6)?
Re: Rounding
eslavko
round.dxf
Version: master
SCM Revision: 2.0.4
Compiler: GNU GCC 4.8.2
Qt Version: 4.8.6
Compiled on: Jun 24 2014
Runing on Ubuntu 14.04
It works corectly on one side of arc but not on other.
Slavko.
Re: Rounding
eslavko
round.dxf
http://forum.librecad.org/Rounding-tp5710609p5710611.html
To unsubscribe from Rounding, click here.
Actualy rounding works but trimming not. If I uncheck Trim (checkbox near Radius entry) then I got added radius and existing lines untact. But If I check Trim then lines are trimmed in wrong side. I just check if I apply radius (without trim) and then trim manualy. And manual trim doesn't work either. (it cut wrong side). So problem is not in "Roun" but in "Trim".
Slavko.
Re: Rounding
Please test behavior in 2.0.6, or even better, in latest git HEAD.
We fixed some trimming behavior after 2.0.4
> round.dxf <http://forum.librecad.org/file/n5710611/round.dxf>
> discussion below:
> [hidden email]
> <http://forum.librecad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5710609&code=ZXNsYXZrb0BnbWFpbC5jb218NTcxMDYwOXwtMjIxMjA4Nzgw>.
> NAML
> <http://forum.librecad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
but in "Trim".
Slavko.
Re: Rounding
eslavko
After enabling ppa:librecad-dev/librecad-daily
and updating to 2.0.7 trimming/rounding works as is expected.
Just hope that this version is not to "unstable".
Slavko.
Re: Rounding
we fixed some crashing bugs since 2.0.6, so, the current git HEAD should be more stable than 2.0.6.
Up to now, the git HEAD has some features working better than 2.0.6 as well.
I am going to push large patch later. While I will try to be careful, more testing/QA is welcome.
eslavko wrote
After enabling |ppa:librecad-dev/librecad-daily|
Slavko.
Re: Rounding
eslavko
For now I will try to stay on daily-ppa. I don't like to compile from source if not absolutely necessary.
Thanks for solving trouble.
Slavko.
Slavko.
http://forum.librecad.org/Rounding-tp5710609p5710619.html
