Will not select entities within a command
PAB
PAB
When using the Trim Command, I cannot select the limmiting entity.  While in the Same Properties command: I cannot select the Original Entity.  Click on and nothing happens.
Re: Will not select entities within a command
Probably the limiting entity is a polyline, that's not possible.
You can explode the polyline to use it for for trimming.
Or is there an overlay image? Images prevents other entities from getting selected.
Put the image on a separate layer and make it invisible to test this.
PAB
PAB
I found the problem.  The curser cross shape for the Trim tool has a small square port in the center that is 3 picsils wide.  When I click with the vertical line in the left and center picsil, no selection, but when I click with the line in the right picsil, the function works properly. Can the selection port be increaced to include all picsil within the selection tool center?
This is unusual. You should provide information about your OS and LibreCAD version (paste Help->About infos), that we can check this with the correct version.
PAB
PAB
HP Laptop 17-cn3xxx,  64-bit operating system, x64-based processor
13th Gen Intel(R) Core(TM) i5-1335U   1.30 GHz
Ram: 32.0 GB (31.7 GB usable)
Windows 11Home
Version 22H2
OS Build 22621.3007
LibreCAD Ver.
Version: 2.2.0.2
Compiler: GNU GCC 13.1.0
Compiled on: Jul 29 2023
Qt Version: 5.12.11
Boost Version: 1.75.0
