Cirkle
7 messages Options Options
Cirkle
Juraj
Why does he draw circles with different lines (very small dashed, dot-dash)?
Re: Cirkle
aman
Usuallly line types in any cad is set in layer configuration.
Re: Cirkle
Juraj
Ok, but the circle doesn't respect the setting by layer. It cannot be changed using element properties either
Re: Cirkle
aman
Create a layer which line type is small dash, then other: line type dash-dot. Then
draw a circle, change layer, draw a circle.
Re: Cirkle
Juraj
https://drive.google.com/file/d/1NCJA7GaJqpfQhm4t9oVnsYiEqYR30ebq/view?usp=sharing
Drawn in one layer, line type dash-dott. Line, ellipse, curve OK, circle...
Re: Cirkle
Confirmed for V 2.2.0. Circle only renders line type continuous properly. Does not occur in 2.13, also seems fixed in the development version 2.2.1 series.
If you desperately need other line types than continuous in 2.2.0 you can cut up a circle at one position with Modify - Divide. It then is an arc and you get the desired line type.
Re: Cirkle
Juraj
Thanks. I used the arch. i will wait for 2.2.1 for w11.
