potential memory leak in dxfrw
5 messages Options Options
This post was updated on Jan 01, 2014; 3:42am.
Rallaz,
can you review my fixes:
https://github.com/LibreCAD/LibreCAD/commit/19c6b9e3759e6ecc36bbb935d7d637fa1ee24eda
I feel more fixes similar are still out there.
more similar fixes in my branch:
https://github.com/dxli/LibreCAD
Re: potential memory leak in dxfrw
I will do it,
But, for compability of older systems and programs I prefer that he does not have  std11 code,
because libdxfrw may be useful for others open source programs and we could have more feedback.
Cheers,
Hi Rallaz,
right now, pretty much every platform supports c++11, so I'm not so worried.
I am not sure whether about the memory leak issue itself:
1, is there actually a memory leak?
2, is the smart pointer a proper fix, given a "yes" answer to question 1?
Thanks,
Dongxu
On Thu, Jan 2, 2014 at 5:33 AM, Rallaz [via LibreCAD] <[hidden email]> wrote:
I will do it,
Cheers,
http://forum.librecad.org/potential-memory-leak-in-dxfrw-tp5709327p5709334.html
Dongxu Li, Ph.D.
www.librecad.org
Hi Rallaz,
I have reverted my changes, because I found it causes segfault with dimensions.
This requires a 2.0.2 release soon.
Hi Dongxu,
The memory leak is present, at least, in drw_variant and drw_header.
I send two commits fixing it.
I made some test in linux and read/write process are OK.
May be a read/write tests in win & osX are required.
Cheers
