text object drawing
15 messages Options
text object drawing
gnagno91
Hi!
I created a method split in rs_actiondrawtext class to split lines of text input for a TEXT object. I'm not able to create appropriate independent objects for each, playing with methods in rs_actiondrawtext class. The split method looks like:
QVector<RS_Text*> RS_ActionDrawText::split(RS_Text *pText, RS_EntityContainer* parent){
    int m = 100;
   for(int i = 0; i < pText->getLines().size(); i++) {
        QString line = pText->getLines().at(i);
         RS_Text* t = new RS_Text(parent, pText->getData());
         t->setText(line);
         RS_Vector point((t->getInsertionPoint().x)+m,t->getInsertionPoint().y);
         t->setInsertionPoint(point);
        list.push_back(t);
    return list;
I modify the init() function and the preparePreview() function in this way:
void RS_ActionDrawText::init(int status) {
    RS_ActionInterface::init(status);
    if (RS_DIALOGFACTORY!=NULL) {
        switch (status) {
        case ShowDialog: {
                reset();
                RS_Text tmp(NULL, data);
                if (RS_DIALOGFACTORY->requestTextDialog(&tmp)) {
                       data = tmp.getData();
                       list = split(&tmp,container);
                        foreach(RS_Text* t, list){
                            RS_TextData obj(t->getInsertionPoint(),
                                            t->getHeight(),
                                            t->getWidth(),
                                            t->getVAlign(),
                                            t->getHAlign(),
                                            t->getText(),
                                            t->getStyle(),
                                            t->getAngle(),
                                            t->getInclination());
                            dataSplitted.append(obj);
                        setStatus(SetPos);
                        showOptions();
                } else {
                    hideOptions();
                    setFinished();
            break;
        case SetPos:
            RS_DIALOGFACTORY->requestOptions(this, true, true);
            deletePreview();
            preview->setVisible(true);
            preparePreview();
            break;
        default:
            break;
void RS_ActionDrawText::preparePreview() {
    for(int i = 0; i < list.size(); i++){
       RS_Text* text = new RS_Text(preview, dataSplitted.at(i));
        text->update();
        preview->addEntity(text);
        textChanged = false;
    data.insertionPoint = pos;
I also added two variable in the class: QVector>RS_Text*> list and QVector<RS_TextData> data.
Luca
Re: text object drawing
Hi Luca,
is there any place to see all the code for the implementation of TEXT and MTEXT?
gnagno91
Here I put the zip file with the work done until today: https://docs.google.com/file/d/0B4NBC6HLgHwWNzZ3cl90a2tteTA/edit.
Luca
gnagno91
Here the link to the lighter zip file: https://docs.google.com/file/d/0B4NBC6HLgHwWbHRnQVgxd3VaYmM/edit
Luca
Hi Luca,
I fixed some building issues in the "luca" branch of my repository:
 https://github.com/dxli/LibreCAD/commit/c18ccb4acaa7ebe21aaa6ad769752f01675a11fc
please update to the HEAD of the luca branch:
https://github.com/dxli/LibreCAD/tree/luca
I only fixed stuff clearly broken to me, while leaving you to play with correctness of implementation. I added an ugly mtext icon for the button in cad toolbar main. the source image file is at:
desktop/graphics_program_icons/mtext.svg
to make it look better, you can use inkscape to edit it and export it png picture ( librecad/res/extui/mtext.png ).
Regards,
Dongxu
On Tue, Jun 12, 2012 at 4:51 PM, gnagno91 [via LibreCAD] <[hidden email]> wrote:
Luca
http://forum.librecad.org/text-object-drawing-tp5706744p5706751.html
Dongxu Li, Ph.D.
www.librecad.org
gnagno91
Which command to update the HEAD? git update or something else?
Luca
Hi luca,
make sure you have my branch added as a "remote":
git remote add -t luca dxli https://github.com:dxli/LibreCAD.git
git fetch --all
git checkout -f -b dxli-branch dxli/luca
if you already have the remote there, you only have to checkout the branch luca from that remote.
if you already have the branch, simply siwtch to the branch and pull:
git checkout dxli-branch
git pull
Regards,
Dongxu
On Wed, Jun 13, 2012 at 8:08 AM, gnagno91 [via LibreCAD] <[hidden email]> wrote:
Luca
http://forum.librecad.org/text-object-drawing-tp5706744p5706755.html
Dongxu Li, Ph.D.
www.librecad.org
gnagno91
Thanks, It seemed something was wrong!
Luca
gnagno91
when running git fetch --all it gives me this error:
fatal: <a href="https://github.com:dxli/LibreCAD.git/info/refs">https://github.com:dxli/LibreCAD.git/info/refs not found: did you run git update-server-info on the server?
is that a problem of my machine?
Luca
Hi Luca:
why not just git clone:
mkdir dxli
cd dxli
git clone https://github.com:dxli/LibreCAD.git
cd LibreCAD
git checkout luca
or download the zip from github:
https://github.com/dxli/LibreCAD/zipball/luca
Regards,
Dongxu
On Wed, Jun 13, 2012 at 10:54 AM, gnagno91 [via LibreCAD] <[hidden email]> wrote:
Luca
http://forum.librecad.org/text-object-drawing-tp5706744p5706758.html
Dongxu Li, Ph.D.
www.librecad.org
In reply to this post by gnagno91
it should be: https://github.com/dxli/LibreCAD.git
instead of https://github.com:dxli/LibreCAD.git
sorry for that!
Dongxu
On Wed, Jun 13, 2012 at 10:56 AM, Dongxu Li <[hidden email]> wrote:
Hi Luca:
mkdir dxli
cd dxli
cd LibreCAD
git checkout luca
Regards,
Dongxu
Luca
Dongxu Li, Ph.D.
www.librecad.org
Dongxu Li, Ph.D.
www.librecad.org
gnagno91
Don't worry! I finally use git clone but it stops compiling at qg_actionfactory.cpp since it say that the RS_ActionDrawMText class has not been declared.
I'll try to fix it.
Thanks,
Luca
Make sure you clone from my repository. I feel your folder is not clean, because qg_actionfactory.cpp doesn't contain string "mtext" here:
https://github.com/dxli/LibreCAD/blob/luca/librecad/src/ui/qg_actionfactory.cpp
Regards,
Dongxu
On Wed, Jun 13, 2012 at 11:26 AM, gnagno91 [via LibreCAD] <[hidden email]> wrote:
I'll try to fix it.
Thanks,
Luca
http://forum.librecad.org/text-object-drawing-tp5706744p5706761.html
Dongxu Li, Ph.D.
www.librecad.org
gnagno91
I will clean my folder asap. I appy your modification and it works, but not yet correctly. I will work on it later.  For tomorrow I will presented the work done and I will explain that we are just concluding the features, saying that my collaboration will continue. For now I will say a big thank you to you and to all the community for the help you gave to me in these months. Anyway, I will continue working on the features I started developing in my free time.
BR
Luca
kevin
i would really appreciate the features i meantioned so i can use this thing with out alot of ddep thought  just to illustrate what i am talking about http://www.facebook.com/photo.php?fbid=333380716735439&set=a.195149723891873.47879.176797659060413&type=1&theater  otherwise this  is how my drawings will look lol
On Thu, Jun 14, 2012 at 4:22 PM, gnagno91 [via LibreCAD] <[hidden email]> wrote:
BR
Luca
http://forum.librecad.org/text-object-drawing-tp5706744p5706767.html
