My first install was LC on Lubuntu 18.04.1 LTS 32 bit, that worked fine, including Print/Export to PDF File.
I now have a laptop with Lubuntu 20.04.2 LTS 64 bit, that will not Print/Export to PDF file.
The same problem has appeared with LibreOffice Writer, so the underlying cause could be related to the change in Desktop Environment introduced by the Lubuntu team.
Although I am chasing this problem via Lubuntu/Ubuntu, this post is simply to enquire if anyone else has been able to correct the problem.
A second laptop with Ubuntu Mate does Print/Export to PDF File from LC ust fine.
Keep well,
John.
