3D Faces
3D Faces
hsrai
LibreCAD 2.0.0 beta compiled on Nov 25, 2012 was able to show a dxf which had 3D faces (exported from BRL-CAD). See attached screenshot. Same file could be opened by SolidWorks, DraftSight, but AutoCAD 2010 could not load same file.
But same file opened with latest code, SCM Revision: 2.0.0beta1-137-gf26a9af Compiled on: Apr 4 2013, show nothing.
What could be the reason?
L shaped 3D object
H.S.Rai
Re: 3D Faces
After open click in zoom->auto. If do not work I can investigate if you attach the file
Re: 3D Faces
hsrai
Issued comand:
 za
and also did view -> Autozoom
Nothing happened :-(
File can be viewed and downloaded from:
 https://docs.google.com/file/d/0BwbGknrjPgERV3U5dk4wSE45Sm8/edit
H.S.Rai
Re: 3D Faces
Test made in win XP latest code:
File->open, select l.dxf
result: file are correct opened and 3dface converted to polylines
File->close, then reopened from recent files list
result: file are opened, layer are present but 3dface are not imported
Conclusion:
This seems a very strange bug, I need more time to investigate.
About opening with AutoCAD:
Layer definition is incomplete, do not have code 70 (flags) and 62 (linetype)
And layer name contains invalid chars "/" & "."
Re: 3D Faces
The problem seems to be that the file is malformed and format autodetection fails considering qcad1 format.
Added a patch to best autodetection. Wait for a new build and test it.
Re: 3D Faces
hsrai
Code pulled from GitHub.
Compiled, it took just about 30.969s
File opened like breeze :-)
Thank you patching so quickly.
With regards,
H.S.Rai
