An easy method orthogonal lines with command line
7 messages Options
jaise
Here some modification to command line input.
L50 or l50 -> left 50 distance [relative]
R50or  r50 -> right 50  distance [relative]
U50 or u50 -> up 50 distance [relative]
D50 or d50 -> down 50 distance [relative]
...\librecad\src\lib\gui\rs_eventhandler.cpp
                if (!e->isAccepted()) {
                    if (cmd.at(0)=='L') {
                        int commaPos = cmd.indexOf('L');
                        bool ok1;
                        double x = RS_Math::eval(cmd.mid(commaPos+1), &ok1);
                        if (ok1 ) {
                            RS_CoordinateEvent ce(RS_Vector(x,0) + relative_zero);
                            currentActions.last()->coordinateEvent(&ce);
                            //                            currentActions[actionIndex]->coordinateEvent(&ce);
                        } else {
                            if (RS_DIALOGFACTORY) {
                                RS_DIALOGFACTORY->commandMessage(
                                            "Expression Syntax Error");
                        e->accept();
                    if (cmd.at(0)=='l') {
                        int commaPos = cmd.indexOf('l');
                        bool ok1;
                        if (ok1 ) {
                        } else {
                        e->accept();
                    if (cmd.at(0)=='R') {
                        int commaPos = cmd.indexOf('R');
                        bool ok1;
                        if (ok1 ) {
                            RS_CoordinateEvent ce(RS_Vector(-x,0) + relative_zero);
                        } else {
                        e->accept();
                    if (cmd.at(0)=='r') {
                        int commaPos = cmd.indexOf('r');
                        bool ok1;
                        if (ok1 ) {
                        } else {
                        e->accept();
                    if (cmd.at(0)=='U') {
                        int commaPos = cmd.indexOf('U');
                        bool ok1;
                        double y = RS_Math::eval(cmd.mid(commaPos+1), &ok1);
                        if (ok1 ) {
                            RS_CoordinateEvent ce(RS_Vector(0,y) + relative_zero);
                        } else {
                        e->accept();
                    if (cmd.at(0)=='u') {
                        int commaPos = cmd.indexOf('u');
                        bool ok1;
                        if (ok1 ) {
                        } else {
                        e->accept();
                    if (cmd.at(0)=='D') {
                        int commaPos = cmd.indexOf('D');
                        bool ok1;
                        if (ok1 ) {
                            RS_CoordinateEvent ce(RS_Vector(0,-y) + relative_zero);
                        } else {
                        e->accept();
                    if (cmd.at(0)=='d') {
                        int commaPos = cmd.indexOf('d');
                        bool ok1;
                        if (ok1 ) {
                        } else {
                        e->accept();
Re: An easy method orthogonal lines with command line
I'm glad to see you are starting to write code.
A big part of programming is figuring out how to avoid repeating code.
Try to simplify what you posted.
Some ideas:
- the || (or) operator http://www.tutorialspoint.com/cplusplus/cpp_operators.htm
- http://doc.qt.io/qt-4.8/qstring.html#toLower
- http://doc.qt.io/qt-4.8/qregexp.html
Now that I have changed the cal command,
and the space-bar functionality:
I'd like to consider adding this
and also some solution for
http://forum.librecad.org/Coordinates-possibility-of-not-using-quot-quot-td5712525.html
Cantar4
agreed, the 779 method will be easier than udrl keyboard dependant strokes.
(that said, thanks to jalse for his triggering proposition :)
jaise
Thank for new feature.
Actually concept of General used Cad is different.
Say example  - Line.
step : First we will pick first point using mouse.
step 2 : next we know line length - 1000mm. We will be mouse in the direction of line. then we will enter line length [100] & press enter or space, line will generate with 1000 unit length in direction mouse position.
or
step 2 :  if line is orthogonal, we need to switch on orthogonal snapping [usually "fn F8" shortcut used or enabling or disabling], then we will enter line length [1000] & press enter or space, line will generate with 1000 unit length in direction mouse position.
But it is nowhere mentioned as line passing through a point with fixed length. But will be very easy as we need to enter only one dimension say length & keep the mouse in direction or position. so orthogonal line can be drawn very fast. just keep mouse in direction we need line, then keep entering sizes.
Note : even if enable orthogonal snap, first point is free snapping for line, rectangle, polygon, circle etc.
If it's done this way, then additionally to orthogonal snapping a new mode with stepped angles, preferably settable, for instance as often used 45°, or if you need finer steps, 15° to also cover 30 and 60°, could be created.
