oldtechie wrote
Changing the background color in options does nothing.  It always stays black.
You may solve your problem with below settings:
Go to
Option >
Appearance >
Graphic Colors >
Background >
#FFFFFF (from drop-down) > Click
OK (and restart LibreCAD).
Because the color you select remains the same even after changing color from
Select Color Window, but won't change due to
drop-down selection did not change
(see the color code when you change accordingly).
It is absolutely working.
