hi,
lots of issues with blocks, we have to clean up this feature in LibreCAD-2.1
I tested blocks containing blocks:
1, I can create a new block from two blocks;
2, I can save this new block as a dxf file using "Save block";
3, I can insert this combined blocks into new drawings. when inserted, the blocks of the new block and its sub-blocks are all listed in block widget;
4, I can edit sub-blocks, but when I edit the parent block, block widget shows nothing, while sub-blocks should be shown. A bug.
I will see whether we can fix this in 2.0 or we should do new implementation of blocks in 2.1
