Bug report: Pen Palette
1 message Options
DmitryArchitect
Hello, here is the bug:
Try to do the following:
Open Pen Palette as Widgets-> Dock Widgets and place it to the right side
Open any other Dock Widget (for example Layer Tree) and place it to the right, below Pen Palette
Then resize right docking area to the narrowest possible.
Now you see that Color, Type and Width drop-downs in Pen Palette are configured as one column (or list) - all of them below Pen Name field.
Now move a border between Pen Palette and another Docker (for example Layer Tree) up to minimize Pen Palette.
And you can notice that Type and Width drop-downs overlap Filter and By Block fields.
So, basically what happens is that top part of a Docker is attached to the top, bottom part is attached to the bottom and they just overlap with each other when one resizes the docker.
I would recommend to introduce scrollbar instead. But probably it's another topic :)
My configuration:
LibreCAD, from "About" section:
LibreCAD 2.2.1.1
Compiler: GNU GCC 14.2.0
Qt Version: 5.15.15
Boost Version: 1.80.0
Flatpak version
My system:
AlmaLinux 9.6
KDE Plasma Version: 5.27.11
KDE Framework Version: 5.115.0
Qt Version: 5.15.9
Kernel Version: 5.14.0
Graphics Platform: X11
NVidia graphics driver
