Bug report: Properties window
1 message Options
DmitryArchitect
If you right-click on a line and choose Edit Properties, then everything is fine.
But if you right-click on a circle and choose Edit Properties, then the Properties window is slightly strange - Pen properties (Color, Width, Line type) are quite narrow and text there is almost unreadable. Well, yes, you can enlarge the window, but nevertheless. And, by the way, Line Properties window could be reduced only to the minimum acceptable and readable sizes of all fields, but Circle Properties window, and especially Ellipse Properties window could be reduced to the 1-pixel size of text. Looks funny, but I believe that it shouldn't be like that.
My configuration:
LibreCAD, from "About" section:
LibreCAD 2.2.1.1
Compiler: GNU GCC 14.2.0
Qt Version: 5.15.15
Boost Version: 1.80.0
Flatpak version
My system:
AlmaLinux 9.6
KDE Plasma Version: 5.27.11
KDE Framework Version: 5.115.0
Qt Version: 5.15.9
Kernel Version: 5.14.0
Graphics Platform: X11
NVidia graphics driver
