Bug report: Status bar options
1 message Options
DmitryArchitect
Options -> Widget options -> Statusbar
The options look and work weird to say the least.
It is not clear what those checkboxes do. Even if they are checked the end result is unpredictable.
The height option tries to do something - the height of status bar slightly changes, but not to the extent of the number you entered. Probably it works after restarting the program.
If you put the font size to zero, the font is still there and surely is quite large.
If you enter large number as a font size, the height of a status bar is not automatically changed to fit that large font, so you end up with an unreadable text.
So, 1) I would remove those checkboxes - they just confuse a user.
2) Fix that Height option and make Height being evaluated from the Font Size if the text doesn't fit.
My configuration:
LibreCAD, from "About" section:
LibreCAD 2.2.1.1
Compiler: GNU GCC 14.2.0
Qt Version: 5.15.15
Boost Version: 1.80.0
Flatpak version
My system:
AlmaLinux 9.6
KDE Plasma Version: 5.27.11
KDE Framework Version: 5.115.0
Qt Version: 5.15.9
Kernel Version: 5.14.0
Graphics Platform: X11
NVidia graphics driver
