BuildLinux error
BuildLinux error
emanuel
Re: BuildLinux error
From your workflow, the only difference is between the git branches, for Linux and Linux arm64.
Please add the cmakelists.txt to your branch. List files in workflow before calling cmake can help.
emanuel
https://github.com/emanuel4you/LibreCAD/actions/runs/18076957532/job/51434838167
I've added an "ls" command before calling cmake. I can see that the CMakeLists.txt file is there. I don't understand what the test is doing, or why it's failing to build in the developer feed. There are no missing files compared to the master branch.
I do not have the permission to read the workflow output
