Builds for Windows
23 messages Options
12
agb
Builds for Windows
agb
Hi, All!
Version 2, build with Qt 5.1.1 at 2013-11-12
Let's test it!
Latest installer is:
https://www.dropbox.com/s/w3hi0pmfjsfmh2q/LibreCAD-Installer.exe
CY,
Anton
Re: Builds for Windows
Thanks a lot for your help!
We would like to provide an Windows installer for users, better by auto-daily build.
If you would like to help the community, please help us achieving this goal!
Regards,
Dongxu
On Wed, Feb 1, 2012 at 6:50 PM, agb [via LibreCAD] <[hidden email]> wrote:
Hi!
Version 2 is very nice! Amazing snap points! )
I make build for windows:
http://dl.dropbox.com/u/1889899/4/LibreCAD-daily/LibreCAD-20120202.zip
How to use:
1. Copy folder of LibreCAD 1 to other location
2. Replace EXE in new folder with EXE from latest archive.
CY,
Anton
http://librecad.1049103.n5.nabble.com/Builds-for-Windows-tp5449181p5449181.html
Dongxu Li, Ph.D.
www.librecad.org
agb
agb
Hello dxli,
I updated my post and add installer.
It is without folders /imageformats, /sqldrivers  - are they needed?
And it includes very big font file wqy-unicode.lff (42Mb) - is it right?  so big?
Now this is hand work... If I will know how to build project from command line in windows - I'll make auto builds.
CY,
Anton
agb
agb
In reply to this post by agb
I update my fist post adding new build:
http://dl.dropbox.com/u/1889899/4/LibreCAD-daily/20120208/LibreCAD-Installer.exe
I changed some files and created new librecad-make.bat for building in windows from command-line (git pull + make + postprocess-win + nsis). To whom I should sent them to add to repositary?
CY,
Anton
agb
agb
Hi Anton,
I wonder whether we can get automatic nightly builds of windows installer. Pretty much the way like ubuntu librecad ppa, which distributes daily builds from the master branch, i.e. 2.0 series currently.
I wanted to add that feature when the 2.0 series is stable enough for beta releasing.
Thanks,
Dongxu
On Wed, Mar 21, 2012 at 7:06 PM, agb [via LibreCAD] <[hidden email]> wrote:
New one:
http://dl.dropbox.com/u/1889899/4/LibreCAD-daily/20120321/LibreCAD-Installer.exe
CY,
Anton
http://forum.librecad.org/Builds-for-Windows-tp5449181p5584315.html
Dongxu Li, Ph.D.
www.librecad.org
agb
agb
>I strongly opt against using a home computer because of risk of viruses in the software.
Untill you find server, I'll make builds eventually.
And everybody, who use my builds, should understand risks (I have avast! worked).
You not protest for this, aren't you? :-)
CY,
Anton
Hi agb,
can you test my windows building scripts as shown in wiki (please help improving wiki also),
LibreCAD Installation from Source
Thanks!
Similar to this bug, we should do code review here:
agb
agb
Hi dxli,
I tested your manual today with qt 5.1.1 and I ready to make changes to
wiki and to build files. Also I need to chat with you in GTalk or skype
to specify some questions. Write me to agb(---)ukr(dot)net, please!
Anton.
02.06.2013 17:13, dxli [via LibreCAD] пишет:
> Hi agb,
> <http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#Building_Windows_Installer_by_NSIS>
> Thanks!
> dxli
CY,
Anton
any update?
agb wrote
Hi dxli,
Anton.
agb
agb
Hi!
I requested account on wiki (Agb), get email confirmation, but I can not
enter bacause I don know password... And also wiki says: "no user Agb".
15.11.2013 5:37, dxli [via LibreCAD] пишет:
> any update?
>     agb wrote
>     Hi dxli,
>     Anton.
CY,
Anton
sp1der
Please try again, I've just fixed this.
agb
agb
Thank you, arct! I updated wiki page http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source according to my latest build experience. Please, try to reproduce! :-)
CY,
Anton
agb
agb
Need to change default Qt path in scripts/set-windows-env.bat now it is wrong.
CY,
Anton
to change the Qt path for your needs, please do as decribed in the wiki:
To change these default settings you have to create the file scripts/custom-windows.bat and overwrite one or both settings without effect to the SCM (git).
Example for scripts/custom-windows.bat:
   set Qt_DIR=D:\files\local\Qt\Qt5.1.1\5.1.1
   set NSIS_DIR=C:\Program Files\NSIS
The custom-windows.bat is ignored by git.
Regards
12
