Calculator precedence
Rahooty
Is there a way to do something like this:
(25+8)/2
Re: Calculator precedence
perepujal
The command line handles some math as direct input:
li
0,(8+2)/3
@20+30<0
will draw a line from 0,3.3333 to 50,3.3333
HTH
Pere
In reply to this post by Rahooty
you can also use the command "cal" in the command line.
Just type to enter "cal", and the command line will be in the calculator mode, so you can type in to calculate:
1+sin(1)
and the output would be:
1+sin(1) = 1.84147098481
type in the command "cal" to quit the calculator mode.
(25+8)/2
perepujal
Nice :)
I see it defaults its input in radians, is there a way to set degrees as default units?
Now if one wants to work with degrees must tell it in the command line:
sin(30d) and the output is
sin(30*pi/180) = 0.5
Thanks
Pere
