Change Global Drawing Orientation
3 messages Options Options
bob82604
New User Question Coming from autocad 2010LT Is there a way to orient the drawing so that drawing a line north from 0,0 @100<0 draws the line up(north) rather than right(east)? I want to use LibreCAD to draw land section plats to export corner points to other software.
Re: Change Global Drawing Orientation
We can implement bearing support.
Before that, maybe you can draw everything the current way. In the end, "Ctl-A" to select everything, use Modify->Rotate to rotate everything 90 degrees.
bob82604 wrote
New User Question
bob82604
That process to to error prone for drawing land section lines from a plat - having to convert all bearings without fat-fingering them.
I may have to look at other options.
