Change arc "bulge" ?
3 messages Options Options
JAQ
JAQ
Hi guys.
New to LibreCAD, but used other packages in the past. My old software is having issues on new hardware so need to update to a more modern cad package.
I'm looking for a "adjust bulge" function. I have a arc in Librecad, and I can select and move the two endpoints, but how to I adjust the bulge, or move the center of the arc, while not moving the endpoints?
In my old cad software, I could select a point along the middle of a arc or line, then drag it in or out to change the arc, while leaving the end points where they were. I could also type in the new radius if I wanted to. Only the arc center point was changed, to suit the existing end point, and give a different curve. Very useful for free hand work, text, artistic stuff.
Thanks in advance.
Glenn
Re: Change arc "bulge" ?
Welcome Glenn!
Sadly there is no such tool in LibreCAD.
You can use Modify->Properties tool to change entities, but changing the radius of an arc will keep the center and thus move the endpoints.
So I recommend to create a new arc and delete the old one.
There are various tools to do so. Possibly, when there is no suitable tool for an arc, you can create a circle, which has more options, and trim it to an arc then.
Maybe Inkscape is a software that is more suitable for free hand and art work.
JAQ
JAQ
Thanks for the reply.
Its a shame Librecad doesn't have this function, its a deal breaker for me unfortunately, otherwise its good software. I use cad for my cnc router which I use for making circuit boards, engraving and fret work, and been able to nudge a arc freehand to tidy up a curve is a must.
In the past I've used a program called Axis Motion ( on a industrial laser cutter ), and have discovered QCad and Sovespace in the last few days, all of which do allow you to adjust a arc in the way I mentioned. They place a point half way along the arc that you can click on and "drag" to change the bulge. Maybe this is something the Librecad developers could consider in a future release.
Regards
Glenn
