Close print PV w/o closing drawing
David L Shumway
Is there any way to close print preview w/o closing drawing?
I, unsuspecting, lost a couple hours of work not knowing I had to be sure to save before going to PV.
Re: Close print PV w/o closing drawing
- toggle the Print Preview tool button
- use File menu -> Print Preview
- close the Print Preview tab or sub window with its close button (right on the tab header or most right above the tool bar for sub windows)
Anyhow, before closing any modified drawing you should be asked if you want to save before closing.
Also there is usually Auto save which may have reduced hours to minutes. These files may be still there if you haven't changed the drawing meanwhile.
