Hi, I don't know if you will be able to reset the zero position in your device, I supose yes, but I don't know that kind of devices.
If you can't, then I warn about preprocessing the point data:
There had been threads complaining that LibreCad does not perform fine that far of origin, so really you want to have the 0,0 point near your data.
If you can't reset the zero point in your device, I suggest to export your data as a .CSV file, preprocess it in a spreadsheet,maybe 3 simple sums/rests for the x.y.z values and reexport it from the spreadsheet as .CSV.
Then the Import ASCII points plugin in LibreCAD is your friend.
HTH
Pere
