Command Line Height
6 messages Options Options
Odi
Command Line Height
Odi
I am using the LCAD 2.2.1 to Windows 10. I usually turn off all GUI, keeping only the Command Line to type the alias. But I can't reduce height the history in command line. I used the mouse on the top edge and pulled, but the minimum size is still too high, taking up too much desktop area. How do I reduce it more?
My screen with command line in minimum size
Re: Command Line Height
sand1024
that's really strange, I couldn't see some limitations for the height...
could you check this on 2.2.2 branch? Here is a screen from my environment (also Win 10) with minimalistic height of command line
Odi
Odi
I think my computer has an incompatibility. I will be migrating to Fedora in a few months.
Couldn't find version 2.2.2 to download. Your screen has very different details than mine.
Odi
Odi
I installed LibreCAD 222 on Windows 11, but it is not opening, displaying the following message:
The procedure entry point could not be located... in the dynamic link library. C:\...
Sorry, continuous build for Windows seems to be broken at the moment.
https://github.com/LibreCAD/LibreCAD/issues/2085
If you have access to Linux you can try the appimage, it works.
