Hi, New to LibreCAD here but long time CAD user for various drawing/drafting tasks.
This package is looking really great ! I am so excited to have found this. Thanks so much to the community. I am wondering if there is a list of commands somewhere that the command line accepts... For instance, I try to type zoom to open up the various zoom-tools but that doesn't do it. Maybe the commands are different or maybe I can dig around in the src repo and find a list somewhere if it works like that. This is awesome! Thanks for the great package! Cheers, jb ps. I am currently running with the most recent (RC1) windows release candidate on a vista system. -j |
Found it in the source repo.. Awesome!
Here is a quick overview for anyone interested: ------------- SNIP ----------------- DRAW CMD: "point" = DrawPoint "po" = DrawPoint "line" = DrawLine "ln" = DrawLine "l" = DrawLine "polyline" = DrawPolyline "offset" = DrawLineParallel "o", "offset" = DrawLineParallel "parallel" = DrawLineParallel "par", "parallel" = DrawLineParallel "arc" = DrawArc3P "a" = DrawArc3P "circle" = DrawCircle "ci" = DrawCircle "rectangle" = DrawLineRectangle "rec" = DrawLineRectangle "rectang" = DrawLineRectangle "polyline" = DrawPolyline "text" = DrawText ZOOM CMD: "regen" = ZoomRedraw "rg", "zoom - redraw" = ZoomRedraw "zr", "zoom - redraw" = ZoomRedraw "zw", "zoom - window" = ZoomWindow "za", "zoom - auto" = ZoomAuto "zp", "zoom - pan" = ZoomPan "zv", "zoom - previous" = ZoomPrevious EDIT CMD: "kill" = EditKillAllActions "k" = EditKillAllActions "undo" = EditUndo "u", "undo" = EditUndo "redo" = EditRedo "r" = EditRedo DIMENSION CMD: "da", "dimension - aligned" = DimAligned "da" = DimAligned "dh", "dimension - horizontal" = DimLinearHor "dh" = DimLinearHor "dr", "dimension - linear" = DimLinear "dr" = DimLinear "dv", "dimension - vertical" = DimLinearVer "dv" = DimLinearVer "ld", "dimension - leader" = DimLeader "ld" = DimLeader TOOL CMD: "dimregen" = ToolRegenerateDimensions MODIFY CMD: "tm", "modify - multi trim (extend)" = ModifyTrim2 "tm" = ModifyTrim2 "xt", "modify - trim (extend)" = ModifyTrim "xt" = ModifyTrim "rm", "modify - trim" = ModifyTrim "rm" = ModifyTrim "mv", "modify - move" = ModifyMove "mv" = ModifyMove "ch", "modify - bevel (chamfer)" = ModifyBevel "ch" = ModifyBevel "mi", "modify - mirror" = ModifyMirror "mi" = ModifyMirror "ro", "modify - rotate" = ModifyRotate "ro" = ModifyRotate "sz", "modify - scale" = ModifyMove "sz" = ModifyMove "ss", "modify - stretch" = ModifyStretch "ss" = ModifyStretch "er", "modify - delete (erase)" = ModifyDelete "er" = ModifyDelete "oo", "modify - undo (oops)" = EditUndo "oo" = EditUndo "uu", "modify - redo" = EditRedo "uu" = EditRedo "xp", "modify - explode" = BlocksExplode "xp" = BlocksExplode SNAP CMD: "os", "snap - none" = SnapFree "os" = SnapFree "sg", "snap - grid" = SnapGrid "sg" = SnapGrid "se", "snap - end" = SnapEndpoint "se" = SnapEndpoint "si", "snap - intersection" = SnapIntersection "si" = SnapIntersection "sn", "snap - center" = SnapCenter "sn" = SnapCenter "sm", "snap - middle" = SnapMiddle "sm" = SnapMiddle "sn", "snap - nearest" = SnapMiddle "sn" = SnapMiddle "np", "snap - nearest point" = SnapOnEntity "np" = SnapOnEntity SELECTION CMD: "tn", "Deselect all" = DeselectAll "tn" = DeselectAll ------------- SNIP ----------------- |
In reply to this post by j.burtner
Hi, I'm new to LibreCAD as well. I had used AutoCAD and IntelliCAD in the past.
I not having too much trouble finding commands via the menu, toolbars etc., but just how do you implement a command on a given selection? e.g., I want to mirror two lines. I select "mirror" toolbar button, and select the two lines (I've also tried reversing the order of these two operations). Then what? I right-click (as in ACAD or Intelli), nothing happens. How do I tell it I'm done selecting? How do I tell it what the mirror line is? Same with moving or copying. How do I tell it I'm done selecting objects, and ready to specify a place to move/copy to? |
Aha! so that little green double-arrow button is the key to the next step.
Thanks! |
Thanks for screencast, but doesn't seem to help me because you are selecting objects (circles in your example).
What I want to do is select a group of lines, choose a mirror line and ..... Mirror. Can't fathom out why Librecad won't let me do what I used to do in Qcad. Would appreciate some help on this. Also, why is there no Delete Segment command in the Modify menu? Regards, Ray |
