Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hi to everyone
Four issues: 1) There are some command shortcuts that do not work well, or just do not work. Apparently, this is due to they are redundant. Then I do a proposal for each of them. (the commands are written between 'apostrophe' and actions between "quotes"): 'a' "angle", "arc" proposals: 'a' to "arc" 'an' to "angle" 'c' "columns", "close", "center" proposals: 'c' to "close" 'ce' to "center" 'co' to "columns" 'l' "length", "line" proposals: 'l' to "line" 'le' to "length" 'r' "radius" "reverse" "redo" proposals: 'r' to "redo" 'ra' to "radius" 'rev' to "reverse" (already there 're' to "reverse direction") Another redundancy: When I write 'cl' in the command line, the application takes the action "linear dimension", but for this exists yet: 'dr'. 2) This is a question: It is possible that the command 'angle' work with polyline arc? 3) The option "Command Language" (Edit -> Application Preferences ...--> Appearance tab), does not take action. The commands, always work only in the language set by the option: "GUI Language". 4) There is a redundancy in the menu "Draw". On the one hand exists Draw-->Line-->Polyline, but it already exists on the other hand, in the group of specific options to draw polylines: Draw-->Polyline-->Polyline, which allows the same functions. I think that should be removed the option: Draw-->Line-->Polyline. Regards Manel |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
also, we probably want to add more commands.
Please review this commit according to your proposal: https://github.com/LibreCAD/LibreCAD/commit/ebbbf12bcf1f3e843d4db50c1071e5e781c00bae
... [show rest of quote]
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Hi Dongxu
I didn't remember the command "length chord", then I have to amend the proposal to the group 'l' Where I said: 'l' "length", "line" proposals: 'l' to "line" 'le' to "length" I would have to say: 'l' "length", "line", "chord length" proposals: 'l' to "line" 'le' to "length" And 'cl' to "chord length" (But also remember you, what I said: "Another redundancy: When I write 'cl' in the command line, the application takes the action "linear dimension" but for this exists yet: 'dr'") For the other groups, are OK Regards Manel |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
done!
https://github.com/LibreCAD/LibreCAD/commit/7d20faf9c074f6d18d02da61fb29a71bdfea478d Thanks!
