Compiling Error ...
6 messages Options Options
Compiling Error ...
Roozbeh
I did follow the "How to built LibreCAD (master branch) on Windows." instructions step by step but I keep getting the following error. would you please let me know whether I'm doing anything wrong? thank you in advance.
Error: dependent '..\..\generated\lib\libdxfrw.a' does not exist.jom: C:\cygwin\home\roozbehg\LibreCAD\librecad\src\Makefile [debug] Error 2
jom: C:\cygwin\home\roozbehg\LibreCAD\librecad\Makefile [sub-src-make_default] Error 2
-Roozbeh (UC Berkeley)
-Roozbeh
Re: Compiling Error ...
Roozbeh
ok never mind I did pass the error .. apparently you need to build the code with "MinGW 4.4 (Qt SDK) Debug or Release" ..
-Roozbeh
Glad it worked out!
When I compile on Windows to make a binary release I always use MingW myself with QT Creator.
or policy is in general that is should work with the standard SDK from Qt.
I know we have a occasional Windows developers in but most of us compile on Linux or OSX,
and thus we don't use the toolchains provided by Microsoft.
Ries
http://forum.librecad.org/Compiling-Error-tp5706658p5706659.html
Roozbeh
thank you Ries for the quick response ..
BTW .. what's your policy regarding using LibreCAD as a preprocessor for a finite element program (free code of course)?
-Roozbeh
Our policy in general is that as long as it's usefull for a set of users and we have the feeling
that the user will maintain the code then we are more then happy to distribute that, preferred as a module.
The more plugin the better!
We are working out new ideas for LibreCAD 3 and it will hopefully have much better plugin interface
than that we currently have. These are currently all ideas, although we do have a codebase we play around with (it's not even alpha quality though).
Ries
http://forum.librecad.org/Compiling-Error-tp5706658p5706661.html
Roozbeh
sounds great Ries. looking forward to seeing that.
-Roozbeh
