Compiling in QT Creator, MSVC2013, Windows 64-bit: Error: dependent '..\..\generated\lib\libmuparser.a' does not exist.
5 messages Options Options
FirstStep
This post was updated on Aug 26, 2016; 7:47pm.
I am building LibreCAD on Windows 10 64-bit. I am using QT Creator with VC2013 and 2015 installed. I download the source code, added the boost paths in custom.pro, opened Librecad.pro and configured the solution as MSVC2013.
I had many errors and I succeeded in getting rid of all of them by doing these:
- In dl_writer_ascii.cpp: Change
snprintf(str,12, "%0X", value);
To
_snprintf(str,12, "%0X", value); in both dxHex() and  dxfReal()
- In Jwwdoc.cpp, add const to all the XXXXXXX::Serialize(std::ofstream& ofstr) functions like this:
void XXXXXXX::Serialize(std::ofstream& ofstr) const <---- { .. }
Now, I only have one more error. One, more, to go.. Which is this:
Could you please tell me what should I do?
I tired adding "-j 1" to the arguments, and it did not do any difference.
This is how my configuration looks like:
https://s11.postimg.org/6iiv5r09v/Capture.png
Please and thanks.
Re: Compiling in QT Creator, MSVC2013, Windows 64-bit: Error: dependent '..\..\generated\lib\libmuparser.a' does not exist.
This is one of the more useful pages http://doc.qt.io/qt-5/qmake-variable-reference.html
There is also muparser.pri
which is included in src.pro
https://github.com/LibreCAD/LibreCAD/blob/master/librecad/src/muparser.pri
PRE_TARGETDEPS += $$GEN_LIB_DIR/libmuparser.a
"Some backends, such as the generators for Visual Studio and Xcode project files, do not support this variable."
http://doc.qt.io/qt-5/qmake-variable-reference.html#pre-targetdeps
I don't know what the alternative is...
