		New user here, working on Windows 7. LibreCad version is
 Version: 2.2.0-rc2-8-g8b2b62d1
 Compiler: GNU GCC 7.3.0
 Compiled on: Mar 17 2021
 Qt Version: 5.12.4
 Boost Version: 1.65.1
 System: Windows 7 SP 1 (6.1)
  I've added a directory in my Application PATHS to hold the font files I convert from either
 TTF ("OpenType Layout, TrueType Outlines" per the windows font viewer)or OTF ("OpenType
 layout, PostScript Outlines") files. I am able to use these new personal fonts in LibreCad.
  The font viewer displays these fonts as "solid filled", whereas using the LFF files to insert
 text into a test document has the text rendered as outline (both display and print).
  This probably makes sense from the description of both original fonts as "Outlines", but is
 there a way I can have these outline texts rendered as solid-filled rather than outlines?
  I've attempted to "explode text into letters" and then use a solid hatch to fill a letter, but the
 hatch operation doesn't recognize the letter as a closed surface.
  Thanks!
  Walt Weber
